I’m trying to support publishing for multiple tasks in Photoshop. The problem is that only the current context is getting used for the Link and Task for all items. I have to set the context manually to get the desired result on the right, even though the Collector seems to know the correct context:
Any ideas how I can make sure the Context is set properly for each item / document?
Hm I thought this worked. Could be a bug.
I’m not sure, since it is currently disabled in the head branch of tk-photoshopcc:
# FIXME: begin temporary workaround
# we use different logic here only because we don't have proper support
# for multi context workflows when templates are in play. So if we have
# a work template configured, for now we'll only collect the current,
# active document. Once we have proper multi context support, we can
# remove this.
if work_template:
I am attempting to get muti-document / multi-context publishing working by overriding this hook and modifying the collector logic.
Actually I don’t know about photoshop. I meant that it works in other engines.
I am working on publishing psd and exr at same time. Which means it falls in multiple context pubish group. Are you able to do multiple publish from photoshop.?
