sgtk.bootstrap.ToolkitManager() not working on Deadline farm cmdLine
I’m trying to bootrstrap SGTK in a deadline command line job to publish exported alembics from maya.standalone (on windows).
The code works without any problem in a local cmd launched on my computer, but it crash on Deadline and I don’t get any error message:
sgtk.LogManager().initialize_custom_handler()
authenticator = sgtk.authentication.ShotgunAuthenticator()
user = authenticator.create_script_user(
    api_script='**********************',
    api_key='**********************',
    host='https://**********************.shotgunstudio.com',)
# bootrstrap based on distributed config
mgr = sgtk.bootstrap.ToolkitManager()
mgr.base_configuration = 'sgtk:descriptor:path?windows_path=*****/*****
mgr.plugin_id = 'basic.shell'
project = {"type": "Project", "id": 155}
engine = mgr.bootstrap_engine("tk-shell", entity=project)
print(engine)
I tried commenting each line from the bottom of the script to see where the problem is exactly, and it seems it works in the deadline job up until I call mgr = sgtk.bootstrap.ToolkitManager()
print(help(sgtk.bootstrap)) or print(help(sgtk.bootstrap.ToolkitManager)) just before calling ToolkitManager gives me the same thing on the farm and in local
Is there any explanation I’m not seeing here? Why would it be different on a cmd launched on the farm and a cmd on my local computer?
Ben
Okay, I found the problem:
sgtk.set_authenticated_user(user) does not seem to work on the farm, sg_user must be passed as an argument when instanciating ToolkitManager
mgr = sgtk.bootstrap.ToolkitManager(sg_user=user)
Is there any reason for it to work in local but not on a farm?
