I’m announcing a few libraries, MIT licensed, that are built to help developers easily build Flow PT apps. There will be more to come.
SG Widgets
shadcn-compatible widgets for FPT: pickers, search, tables, trees, grids, cards, filter and field editors. React and Svelte, themed by shadcn tokens, installed as source with one command.
Roughly sixty widgets per framework, a page per widget with a live demo. Sign in with your own site and the demos show your data. Paste any shadcn theme, tweakcn included, and you can save it and preview it site wide.
Docs and demos: https://sg-widgets.vercel.app
Core on npm: https://www.npmjs.com/package/sg-widgets-core
SG Widgets Qt
The same widgets ported to PyQt/PySide, largely with AI. Behaviour still needs polish, and there will be bugs.
Code: GitHub - ksallee/sg-widgets-qt · GitHub
PyPI: Client Challenge
SG Notes
A notes workbench built on SG Widgets in about five hours with Claude. Reply to many notes at once, close, mark read, change recipients, forward. Sign in with your own site; nothing is stored.
Code: GitHub - ksallee/sg-notes · GitHub
Live: https://sg-notes.vercel.app
From last week:
SG Groundtruth
Measured behaviour of the FPT REST API, from scripts run against a real site. Findings and recipes your agents can ground on.
Site: https://sg-groundtruth.vercel.app
SG ComfyUI
Load and Publish nodes for ComfyUI.
Code: GitHub - ksallee/sg-comfyui · GitHub
Groundtruth and the widgets are the base for apps on production data, the way Toolkit is for asset management. SG Notes is what one such app looks like: clone it, theme it, change it.
Next: repos that set a standard “template” for these apps (thinking about commands registration, event subscription, etc)
If you want to build on this, test it, or break it, ping me. Stars on GitHub repos help too.
I hope you like them! Definitely let me know what you think, it’s really helpful to improve them.
