RV Swap Media
Hi
There seems to be a bug with swapping Shotgun Version media through RV.
When using the right mouse button click menu “Shotgun > Swap Media > Play xxx”, nothing happens. But when using the top bar menu “Shotgun > Swap Media”, it does work.
This bug was found using RV 7.3.0 on CentOS 7.
Thanks for checking into this.
Cheers
Cedric
Hi Cedric,
Welcome to the forums! I’ll flag with the RV team as I don’t have a linux box to test on. Are you able to upgrade to the latest version of RV, 7.5.1? There are a lot of improvements between 7.3 and 7.5.1, it could be a quick solution? Also with post RV7.5.0 it now uses QT5 and I’ve noticed considerable speed improvements.
Hi David
Thanks, different look than the support page for sure.
Was very eager to see the roadmap on here, thanks for that.
This shouldn’t be a problem, I will try and report back to you.
Cheers
Cedric
Hi David
Can confirm, bug is fixed in 7.5.1.
It indeed is faster as well.
Thanks for the help!
Cheers
Cedric
No Problem Cedric, glad that worked for you!
