Hello Folks from the Rv Realm
rv2022,
have a few questions ,
while an artist publishes from a dcc(ex nuke) ,
a sequence from a folder (browse folders to publish images) from the folder structure /mnt/project/…,which shotgrid recoganises, from what i have gathered from earlier posts and documentation, the normal work flow would be to write the path field attribute if the versions has “sg_path_to_frames”, and until here it is good and it has path field filled up in shotgrid web,
but although the the sequence contains a version number , the published version does not seem to update ,
biut when a mov is uploaded with a version number , in shotgrid web it shows the correct version number
1: how do i get the correct version number info for the sequence of frames to be displayed in shotgrid web
2: how do i get the path_cache info for the current mov /exr in rv
3: how do i get the vesrion number info for the current mov/exr in rv
when i query the metadata i do not see any version number ,
using
info = extra_commands.sourceMetaInfoAtFrame(commands.frame())
metadata = commands.sourceMediaInfo(info['node'])
i only get file and other values but not version number
any pointers would be greatly apritiated ![]()
