All of RV licensing requirements are handled through tweak@autodesk.com email alias. Please email them directly with your purchasing request. In order to make this process easier and faster, please take a look at some of the easy to provide information below that Tweak will ask for.
Here are the types of common requests:
New license (RV, RVSDI, RVIO) that isn’t licensed through Shotgun. Here is the minimum info required(though Tweak sales team will likely have followup billing questions):
Email Subject: New RV (RVSDI/RVIO) license request
Name: Your full name
Email address: Your email address that you’d like to associate with new license
Product type: RV, RVSDI or RVIO and earliest version you need.
Number of Licenses: The number of licenses you’re requesting, default is 1.
Mac Address(es) RV licenses are either float or node-locked, depending on what Mac address you specify. If you specify a license server, then you will be able to float the license, by using our TLM Server. You can learn how to set up license server here. How do I find my MAC HostID?
Upgrade license (RV, RVSDI, RVIO) OR maintenance that isn’t licensed through Shotgun. Here is the minimum info required(though Tweak sales team will likely have followup billing questions):
Email Subject: Upgrade RV (RVSDI/RVIO) license request
Mac Address(es) (if different from request) RV licenses are either float or node-locked, depending on what Mac address you specify. If you specify a license server, then you will be able to float the license, by using our TLM Server. You can learn how to set up license server here. How do I find my MAC HostID?NOTE: Please attach your existing license to the email.
Transfer to a new Mac Address. Here is the minimum info required:
Email Subject: Transfer RV (RVSDI/RVIO) license request
Mac Address(es) Your new mac address that you want to transfer RV to. RV licenses are either float or node-locked, depending on what Mac address you specify. If you specify a license server, then you will be able to float the license, by using our TLM Server. You can learn how to set up license server here. How do I find my MAC HostID?NOTE: Please attach your existing license to the email.
Some other FAQ about RV licenses:
