RV 2026.0.0 Release is available!
Release Date: July 16, 2026
Download available here.
IMPORTANT: RV 2026 is the last release to support Intel-based Macs.
We are happy to announce the release of RV 2026.0.0!
This release brings several upgrades and stability to the application to be compliant with the VFX Reference Platform CY2025.
This release also brings new features by adding Shapes and Text support to the Annotation toolset, as well as the possibility to have Thumbnails and Filmstrips generated for the media sources in RV’s Session Manager.
Known Issues
  • 10-bit monitor output with Qt6 is not supported in this release. [SG-42267]
  • Side-by-side Compare mode does not work as expected while sharing a Playlist in a Live Review session with Review player if Continuous Playback is enable. [SG-44116]
New Features
  • Session Manager now generates and displays thumbnails and filmstrips for local and Flow Production Tracking media sources. Thumbnails and filmstrips refresh automatically when a source is modified, so previews stay in sync with the underlying media. A new Session Manager setting lets you turn thumbnail generation off when you want to reduce overhead or skip previews entirely. [SG-42109]
  • Shape and text annotations — The annotation tool now supports Shapes and Text. These annotations can be shared within a Live Review session between RV and Flow Production Tracking Review. [SG-42887]
  • Live Review sessions are now properly left after a period of user inactivity. [SG-43259]
  • The selected OCIO config is now saved in RV’s settings, resolving an “OCIO environment variable not set” error after activating the feature. [SG-35309]
  • Added an alt/option hotkey and environment variable ( RV_NO_SEQUENCE_PATTERN) to prevent RV from loading images as an image sequence. [SG-41979]
  • Added crash-dump generation capabilities to RV. [SG-42630]
  • Added support for AJA 12G-SDI output over a single link. [SG-27382, SG-42264]
SDK / Platform Updates
  • Updated AJA SDK to version 17.6.0. [SG-42175]
  • Updated Boost to 1.85.0 (VFX Reference Platform CY2025). [SG-42380]
  • Updated NumPy to 1.26.4 (VFX Reference Platform CY2025). [SG-42372]
  • Updated OpenEXR to 3.3.6 (VFX Reference Platform CY2025). [SG-42374]
  • Updated OCIO to 2.4.2 (VFX Reference Platform CY2025). [SG-42375]
  • Updated minimum Visual Studio platform toolset to 17.6 (VFX Reference Platform CY2025). [SG-42373]
  • Updated FFmpeg to version 8.0. [SG-42382]
  • Refactored Apple ProRes decoding. [SG-42419]
  • Rebuilt OpenSSL 3.0.0 with enable-md2 to restore MD2 symbol support. [SG-43099]
  • Addressed libpng vulnerability CVE-2026-25646. [SG-42121]
Bug Fixes
  • Fixed events from previous connections still being processed after rejoining a Live Review session. [SG-41466]
  • Fixed a warning when joining an RV-to-RV Live Review session: “Failed to retrieve session metadata (status=403)”. [SG-42489]
  • Fixed missing annotations on RV. [SG-43249]
  • Fixed frames with an annotation plus an erased annotation getting stuck in Hold mode during Live Review sessions with Flow Production Tracking Review. [SG-43908]
  • Fixed the text annotation size slider no longer being taken into account. [SG-43924]
  • Fixed rvio crashing on startup when using a session file containing text annotations. [SG-44083]
  • Fixed a long path issue on Windows. [SG-35913]
  • Fixed the Console “Show on” option resetting to the first option on restart. [SG-40350]
  • Fixed a BMD SDI bug showing a green line on the right side of the screen in YCbCr 10-bit DCI resolutions. [SG-42272]
  • Fixed random crashes involving SoundTrackIPNode. [SG-42334]
  • Fixed GLSL errors reported in the console on Windows (and Linux) with AMD. [SG-42604]
  • Fixed RVIO segfaulting (exit code 11) after transcoding a file sequence for submit on Rocky Linux 9. [SG-42890]
  • Fixed a crash in Flow Production Tracking RV when a Wacom tablet is mapped to a display not aligned with the rest. [SG-42902]
  • Fixed Favorites and Visible Fields preferences from the Screening Room browser not being saved when relaunching the application. [SG-42921]
  • Fixed issues with GLSL shader fragments and programs on AMD. [SG-43255]
  • Improved robustness when handling unknown schemas during OTIO import. [OpenRV #1341]
OpenRV Community Contributions
  • Added 60 and 59.94 fps options to the Control FPS menu. [SG-42880]
  • Added Dissolve blend composite mode to stackIPNode, with UI controls. [SG-41316]
  • Migrated to OpenImageIO (OIIO) 3.1.12.0 and build with OCIO. [SG-42131, SG-40796]
  • Disabled x11 features on macOS. [SG-42137]
  • Added Alt modifier check for mouse wheel events to support horizontal scroll. [SG-41698]
  • Fixed an off-by-one frame count error for audio-only files. [SG-42144]
  • Fixed a crash when adding a session file alongside media files. [SG-43602]
  • Bounds-checked start/num in get*Property commands to prevent out-of-range access. [SG-43603]
  • Fixed ACES 2 displaying black. [SG-43392, SG-43607]
  • Added a thread-safe consoleWrite command for Python console output. [SG-43604]
  • Updated openjpeg 2.5.0 → 2.5.4. [SG-43297]
  • Updated libatomic_ops 7.7 → 7.10. [SG-43299]
  • Updated doctest 2.4.9 → 2.4.12. [SG-43308]
  • Updated pcre2 10.43 → 10.47. [SG-43309]
  • Updated webp 1.2.1 → 1.6.0. [SG-43311]
  • Updated libtiff 4.6.0 → 4.7.1. [SG-43313]
  • Updated libraw 0.21.1 → 0.22.0. [SG-43398]
I’m sorry to report this again and a ticket is already logged about it (SG-40456), but opening any commercial codecs (like H264) from a RV session that wasn’t authenticated, won’t load the media.
Steps to reproduce:
On Linux:
  1. Clear your authentication cache (~.rv, ~./config/TweakSoftware, ~/.local/share/TweakSoftware)
  2. Open a h264 media through CLI (/opt/RV/bin/rv /my/file.mov)
  3. Authenticate RV (here in 2025.0.0 rv crashed. Now we can authenticate since 2025.1.0)
  4. When Authenticated, that RV session won’t recognize any commercial ffmpeg codec (thus the H264 media we just tried to open)
Expected Behavior:
Opening a H264 media while RV isn’t authenticated, the H264 media should be able to load without any issue after the user has authenticated (without closing reopening RV)
Workaround
Close RV and re-open RV. But this workaround isn’t a viable since we are using RV as our default media player in Maya for animators. So every now and then, animators doesnt undertand why “RV cannot open their playblast”.
** For this reason alone, we are stuck using RV 2023
Probably the source of the issue
I believe the source of the issue is because RV is loading the mio_ffmpeg_commercial.so library only if RV is already authenticated. If RV wasn’t authenticated, RV won’t try to load mio_ffmpeg_commercial.so again after the user authenticate
switching media representations from mov to frames is not wroking anymore in 2026. 2025.1.1 is working flawlessly in that regard.
Testing with an untouched vanilla version on Windows 11.
After switching multiple times to Frames its working (as can bee seen in the logs).
We are sticking to the 2025 releases for now.
Best,
Tobi
Hey @pixelconductor
Thank you for flagging this our team will take a look and see what is going on. Please stay tuned for updates.
Tommy
Hello Tobi,
I just wanted to let you know that we have released an RV 2026.0.1 patch release that addresses this issue. The issue was caused by the -debug mu flag which was incorrectly enabled by default. This is no longer the case. Sorry about that.
Hello @sbissonnette,
Thank you! Will give that versoin a try soon.
Thanks @bernie for letting me know!
Just tested with 2026.0.1 and I can finally confirm this is now working as expected!
Thank you so much for addressing this!
We recently moved to this version and Live Review now defaults to “Collaberation” Mode.
Is there a way to default to “Presentation” Mode for all uses.
We are running into issues with “Collaberation” Mode and our custom plugins.
Hey @oscar thank you for reaching out. Currently Collaboration is on by default, I have taken down the request to be able to set that in the settings. With that said we are moving towards having roles within a live review so you could simply set a “host” and everyone else as viewers. In the meantime I can send you a package that could install on the RV system that drives the RV Live Review session also known as the “host”. I can message you that package.
Tommy
