RestAPI - view History
It is possible to fetch the history (modifications) of a field via the RestAPI (
Hi @eeight ,
Yes, that’s possible. The history is stored as an entity in SG. You can use the /entity/event_log_entrys endpoint. https://developer.shotgridsoftware.com/rest-api/#read-all-records
With a filter that matches the field entity (“Link”) and the field attribute_name (“Attribute Name”) to whatever you need.
Martin
Note: I’m not 100% sure about the mangling of EventLogEntry to event_log_entrys but I think that this is correct.
Hi @mminsel
Thank you, but I don’t have access to older history, it’s stopping at: 759,017 for me (I am using the web-ui for now).
Any idea?
Hi @eeight ,
In your ShotGrid (SG) preferences you’ll find: grafik
SG creates many EventLogEntries, so that storing all of them forever seems unfeasible.
Alternatively it could also be that your page-filter is stopping you from seeing more events. By default it is set to 4 weeks:
Is there a form to request a dump of the archive for this entity (.sql, .csv, …). We need the history of the EventLogEntries since the creation of our site (> 6 months).
I guess, this would be a request to the ShotGrid support.
