Rest API with multiple Filters
Using PHP to get data via the REST API and struggling a bit with the filters. I want to get the Time Logs for a specific user on a specific date. Getting them by user was pretty straight forward
&filter[task_assignees.HumanUser.login]=username
However, adding to include a specific date has been troublesome.
&filters[["user.HumanUser.login", "is", "username"],["date", "is, "2019-10-09"]]
That gets me nothing. Multiple filters just isn’t clear to me.
Using cURL and GET
Apparently,
&filter[user.HumanUser.login]=username&filter[date]=actualdate
Seems to be the answer. Please correct if this is wrong.
Hey Chad – welcome to the forums!
I’m glad you were able to find a solution here. What you’re doing works, but it’s limited: your syntax works because the relation between your two filters is an and one, and you are filtering on two different fields. If you wanted to do a query with an or or some other relation between filters, or if you for example, wanted to find a date between two values with queries like “date > foo” and “date < bar”, then stringing together filters with & as you did wouldn’t work.
In order to support more complex cases, you’ll want to use the _search endpoint as documented here.
I was unable to get the search to work. As it happens, I have a question specific to getting timelogs between 2 dates in another thread.
I will attempt using search again and post any further queries or findings there.
Thank you for better explanation.
