Filter seems not working, by giving wrong params?
I cound’t found exact anser here. If it’s already solved thing, I’m sorry.
I tested below code to get an exact user.
But in this code, I got all users info, that appearently the filter doesn’t work properly.
I’m quite newbie to do this around.
Hope someone helps. Thanks.
let res = await axios.get(
    "https://xxx.shotgunstudio.com/api/v1/entity/HumanUser",
        headers: {
            "Content-Type":"application/vnd+shotgun.api3_array+json",
            Accept: "application/json",
            Authorization: "Bearer" + ` ${access_token}`,
        params: {
            fields: "*",
            filters: [["id", "is", 127]],
// Output to check
console.log(res.data.data.length);
console.log(res.data);
returns all users info without no errors
