Remove/ignore frame from playback for retiming purposes
Hi, I heard there was a way to scroll to a frame or multiple frames and remove them from playback for retiming purposes. Is this possible with the default tools or is it a script?
Hi Mikyki,
That sounds like a custom tool. If you are willing to do some programming, it could be implemented using the ‘explicit’ retime feature of a retime node.
Essentially, that gives you complete control over what frame is where (including duplicating, omitting, and/or out-of-sequence frames)
Hi Michael, thanks for the response! Unfortunately I’m not familiar with how to do that. Hopefully I can get the tool from the source.
