Refreshing Configuration cache when pipeline config is updated
When updating folder Schema or Pipeline Steps, how do I force the cache to be updated?
Donna
Hi Donna - You’re talking about the path cache? There are a few things to note here:
  • As I mentioned in your other post, , tank folders on the given entity will update the path cache.
  • If you want to do it programmatically, the create_filesystem_structure() method is the Toolkit API equivalent of tank folders.
  • Note that these steps won’t affect PublishedFiles or Versions – if the paths to Published Files or Versions change, you’ll need to modify the path specified in the corresponding entities as well.
In general (in case it’s not clear :slight_smile: ) , we strongly advise that you try and lock down your folder structure and entity naming as much as possible before you start building out your production filesystem with Toolkit, but I understand that that’s sometimes unrealistic in actual production.
Right, I understand locking things down as much as possible. For now I’m only updating things in my development area. because the folder structure is still being designed. So i will only need to refresh the cache for my dvlp area. as things change.
Thanks for your help!
Gotcha. Makes sense. Good luck!
thanks!
