Python code to change layers while viewing an EXR file in RV
I have created an EXR file with multiple layers and want to switch between these layers using a Python script in RV. However, I am unable to determine where the layer information is stored. How should I approach this using Python?
have you enabled the LayerSelect mode package? It might already do what you are trying to do. If nothing else, it might help answer your question.
