When running the watcher, and I can see the logs / config / py / and ID files; but the PID file doesn’t seem to be in the /src/ directory like it says in the config file that it should be.
I’m running the watcher via “python shotgunEventDaemon.py start”, and it runs just fine, but I can’t seem to find the PID file in that directory; the only files in the /src/ directory are the conf, id, logs, and py files. I’m running this on Windows. Is there some other way I need to be running this to see it?
