Need that when supervisor requires to , he/she should be able to view published exrs from photoshop in shotgrid. How can that be made possible ?
There are hooks for this in the photoshop tk engine, but they need to be configured.
This is an excerpt from our configuration, which goes under the tk-photoshopcc engine
tk-multi-publish2:
collector: '{self}/collector.py:{engine}/tk-multi-publish2/basic/collector.py'
collector_settings:
Work Template: photoshop_shot_work
Publish Template: photoshop_shot_publish
publish_plugins:
- name: Publish Scene
hook: '{self}/publish_file.py:{engine}/tk-multi-publish2/basic/publish_document.py'
settings:
- name: Create Version
hook: '{self}/publish_file.py:{engine}/tk-multi-publish2/basic/upload_version.py'
settings:
Thank you @mmoshev for the reply. If I am asked to view version’s instead of published files, how to view them ?
Can I move further on in direction of the question. To implement what you have suggested, I need to take over the tk-photoshopcc app. Their is a folder where all customised apps are located with the config pointing to this folder.
Every app, example tk-multi-publish2, has an app.py module with
class MultiPublish2(sgtk.platform.Application):
tk-photoshopcc by default does not have this module. This is a problem as it results in publish icon missing from shotgrid panel in photoshop.
How to implement this, in proper design perspective ?
Hey, you should not take over the app. Taking over a publish hook would be enough. Did you look through the video tutorial I suggested earlier? It should explain to you how to publish something specific you need. Also, try to search here on the community platform.
