Nuke Studio Export - name 'StandardError' is not defined
Hello, I am trying to run an export from Nuke Studio opened via the Flow Production Tracking desktop app. When trying to run the export I get this error message that says “name ‘StandardError’ is not defined”. The export does not run and I am not sure where in the toolkit this bug is located. Does anyone know?
I told you in the other thread - this is a Python 2 error. Python 2 was sunset on 1 jan, 2020.
The plugin needs to be updated to Python 3.
Its indeed very likely a Python2/3 issue.
What version of Nuke are you running and who is maintaining your Toolkit configs?
Yes, this was the issue in the hiero_get_shot.py file where it was trying to run a StandardError statement and I replaced with an Expection but now the export is not running as it should. I am maintining the toolkit configs but still trying to learn. Any advice for a beginner?
You would probably want the traceback from that hook to figure out whats happening.
Get used to reading logs - one of the most frequently employed skills :slight_smile:
Could you elaborate on the issue? Are there any visible error messages?
