Notes / Filter by Pipeline step
Problem
  • My supervisors is asking for filter notes by Pipeline Step (for notes linked to one or multiple Tasks).
  • Web app allows me only to filter notes by Task or to create Saved Filter for each pipeline steps. Those two solutions are not interesting.
  • Then I can also create new fields called “Pipeline step”, but it will have to relink all notes manually…
Question
  • Can you add one option for list all pipeline steps link on the current note ?
  • Can Dev team add custom filters (with Python Api) in Shotgrid web app for filter by Pipeline Step ?
Thank you for your help,
Kévin Z
Fix Studio | France
Hi Kevin,
You’ll need to create a new filter.
For this you need to do the following steps:
  1. Filter, scroll down to “My Note Filters”
  2. Press +
  3. Name the Filter
  4. Hit the +
  5. In the first field, scroll down to “Tasks”, hover and select scroll down to “Pipeline Step” hover and select “Short Code”
  6. Then select the condition “is”
  7. enter the step-code you want to filter. For instance “anim” image
  8. confirming with “Create” will create your filter.
Hope that helps.
Martin
Hello Martin,
Nice ! Thank you very much for your answer !
