New YML build UI resources
Hello hivemind, does anyone know about the new “YML build UI resources” for building out the Toolkit app UI files and resources file?
Seems like the build system got updated around Sept 2024, there is mention of it in the release notes of TK Core and several apps but I can’t find any documentation on it. The old “build_resources.sh” files are missing in the latest app releases too.
Additionally, they have removed the traditional QT import statements from the compiled UI files and replaced them with the following (which seems a little janky).
from tank.platform.qt import QtCore
for name, cls in QtCore.dict.items():
if isinstance(cls, type): globals()[name] = cls
from tank.platform.qt import QtGui
for name, cls in QtGui.dict.items():
Answering my own question here, it looks like there is a new script that is part of the tk-toolchain for compiling the ui and resource files.
Some notes for my future self and others
  • You have to use PySide2 (PySide6 does not work) which is only compatible with Python 3.10.x, not Python 3.11.9 that ships with SG Desktop
  • tk-build-qt-resources needs to be run from the directory containing the build_resources.yml file
  • The legacy build_resources.sh does not work, I had to use the new tk-toolchain “tk-build-qt-resources” function which replaces the import statements:
    • (the traditional) from tank.platform.qt import QtCore, QtGui
    • with: from tank.platform.qt import QtCore
This is really ugly since it pollutes the namespace but I think this stems from a change in how pyside2-uic.exe compiles the UI files, as it imports all of the class names instead of QtCore & QtGui as it previously did.
Thanks for sharing this!
You’re absolutely right—tk-build-qt-resources is now the correct way to compile UI and resource files, replacing the old build_resources.sh. The new import structure using globals() might seem unconventional, but it was necessary to align with how PySide2 processes compiled UI files.
One key point to emphasize is that PySide6 is not supported, and the build system currently requires PySide2 with Python 3.10. This is important to keep in mind, especially since SG Desktop ships with Python 3.11.9, which can lead to compatibility issues if not handled correctly.
For anyone needing more details, the official documentation can be found here:
tk-toolchain - tk-build-qt-resources
It’s been a year since this last update. Are there any new developments planned? Specifically around supporting PySide6?
Especially since the last update in the repo was:
SG-40980 Add support for VFX CY2026 - Python 3.13 - Qt 6.8 (#82) · shotgunsoftware/tk-toolchain@538f78e · GitHub.
However this update does nothing to update tk-build-qt-resources so we’re still stuck with PySide2?
cheers,
kp
I did it by manually specify both -u and -r e.g.
tk-build-qt-resources -u .venv/bin/pyside6-uic -r .venv/bin/pyside6-rcc
Hi @kporangehat, we had developments planned on this but priorities changed since then.
Could you share specifics of changes you would need?
