Tk-toolchain UI discrepancies when building with tk-build-qt-resources
EDIT: Solved, leaving this here in case any one else faces this issue. The latest versions of QT Creator w/ Designer are built using QT6 and WILL NOT work properly with QT5 tooling.
More info here:
I ended up using this version succesfully.
We recently upgraded one of our apps to use the tk-build-qt-resources tooling, updating it from the build_resources.sh approach.
However now, our app doesn’t look like its designer file, more specifically, vertical spacers are not matching the designer file anymore leaving the layout looking, well frankly, terrible.
Has anyone else faced this issue. Trying to pinpoint whether the issue is with the tooling approach, with an update to creator, or with an update to FPT itself is proving to be a bear.
