Release date: October 7, 2021
Bug fixes
Toolkit
- Fixed an issue in
tk-framework-desktopclientto correctly detects ShotGrid Create on the filesystem. [SG-23055] - Fixed an issue where ShotGrid Create’s DLLs path was injected in launched tool’s DLLs path and could cause launch applications failures because of conflicting DLLs. [SG-18781]
Playlists
- Playlist versions stream and timeline version orderings are different when ‘‘Playlist → Sort Order’’ field is empty in ShotGrid. [SG-22819]
 - Quickly switching between playlists can lead to a crash. [SG-22715]
Player
- With ranges disabled, adding IN or OUT range doesn’t enable ranges AND set the specified range. [SG-22683]
 - Range Hotkeys: It should not be possible to set a IN point after an OUT point using the hotkeys. [SG-22682]
Full Release Notes for all Create releases can always be found here.
