I’m still fumbling around as I set up a toolkit project. I went through the steps and it made the configs, but it put them one level up from where I wanted. So, I looked a the docs and ran tank move_configuration. However, it seems to be recursively copying the files in my folder. Maybe I’m misunderstanding what’s going on.
Here’s what I got after I ran the toolkit config initially:
- assets
- cache
- config
- editorial
- install
- reference
- sequences
- sg
- tank
- tank.bat
And this happens when I try to run the move command. It just keeps copying everything recursively.
In the past, I’ve had a folder that kept the sequences and other top level folders there and had all the config stuff in a folder called ‘sg’. Not sure what I’m doing wrong. Here’s my command line output.
Z:\Motion_Design\OrgMovies\PINE\VFX>tank move_configuration “/foo/sg” “\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\sg” “fs6.insp.com/CP_P/Motion_Design/OrgMovies/PINE/VFX/sg”
Welcome to the Shotgun Pipeline Toolkit!
For documentation, see https://support.shotgunsoftware.com
Starting toolkit for path ‘Z:\Motion_Design\OrgMovies\PINE\VFX’
- The path is not associated with any Shotgun object.
- Falling back on default project settings.
- Running as user ‘byron’
- Using configuration ‘Primary’ and Core v0.19.18
- Setting the Context to Project Christmas in the Pines.
- Running command move_configuration…
Command: Move configuration
Current Paths
Current Linux Path: ‘/foo/sg’
Current Windows Path: ‘\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX’
Current Mac Path: ‘None’New Paths
New Linux Path: No change
New Windows Path: ‘\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\sg’
New Mac Path: ‘fs6.insp.com/CP_P/Motion_Design/OrgMovies/PINE/VFX/sg’The configuration will be moved to reflect the specified path changes.
Note for advanced users: If your configuration is localized and you have other
projects which are linked to the core API embedded in this configuration,
these links must be manually updated after the move operation.Are you sure you want to move your configuration? [Yes/No] yes
Copying ‘\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX’ →
Copying \fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\assets…
Copying \fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\cache…
Copying \fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\config…
Copying \fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\config\core…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\config\core\hooks…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\config\core\schema…
Copying \fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\config\env…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\config\env\includes…
Copying \fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\config\hooks…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\config\hooks\tk-multi-launchapp…
Copying \fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\config\icons…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\config\tk-metadata…
Copying \fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\editorial…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\editorial\publish…
Copying \fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\editorial\work…
Copying \fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install…
Copying \fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\apps…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-3dsmax…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-3dsmaxplus…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-aftereffects…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-alias…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-desktop…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-desktop2…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-flame…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-flame-export…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-flame-review…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-framework-adminui…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-framework-adobe…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-framework-aliastranslations…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-framework-desktopclient…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-framework-desktopserver…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-framework-lmv…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-framework-qtwidgets…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-framework-shotgunutils…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-framework-widget…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-hiero-export…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-hiero-openinshotgun…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-houdini…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-houdini-alembicnode…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-houdini-mantranode…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-mari…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-mari-projectmanager…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-maya…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-motionbuilder…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-multi-about…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-multi-breakdown…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-multi-demo…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-multi-devutils…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-multi-launchapp…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-multi-loader2…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-multi-publish2…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-multi-pythonconsole…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-multi-reviewsubmission…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-multi-screeningroom…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-multi-setframerange…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-multi-shotgunpanel…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-multi-snapshot…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-multi-workfiles2…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-nuke…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-nuke-quickreview…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-nuke-writenode…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-photoshopcc…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-shell…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-shotgun…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-shotgun-folders…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-shotgun-launchfolder…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-shotgun-launchpublish…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-shotgun-launchvredreview…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\app_store\tk-vred…
Copying \fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\core…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\core\developer…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\core\hooks…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\core\python…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\core\scripts…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\core\setup…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\core\tk-metadata…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\core.backup…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\core.backup\20210211_143257…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\engines…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\install\frameworks…
Copying \fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\reference…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\reference\artwork…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\reference\footage…
Copying \fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\sequences…
Copying \fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\sg…
Copying \fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\sg\assets…
Copying \fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\sg\cache…
Copying \fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\sg\config…
Copying \fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\sg\config\core…
Copying \fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\sg\config\env…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\sg\config\hooks…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\sg\config\icons…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\sg\config\tk-metadata…
Copying \fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\sg\editorial…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\sg\editorial\publish…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\sg\editorial\work…
Copying \fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\sg\install…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\sg\install\apps…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\sg\install\app_store…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\sg\install\core…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\sg\install\core.backup…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\sg\install\engines…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\sg\install\frameworks…
Copying \fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\sg\reference…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\sg\reference\artwork…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\sg\reference\footage…
Copying \fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\sg\sequences…
Copying \fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\sg\sg…
Copying \fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\sg\sg\assets…
Copying \fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\sg\sg\cache…
Copying \fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\sg\sg\config…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\sg\sg\editorial…
Copying \fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\sg\sg\install…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\sg\sg\reference…
Copying
\fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\sg\sg\sequences…
Copying \fs6.insp.com\CP_P\Motion_Design\OrgMovies\PINE\VFX\sg\sg\sg…Exiting.
Terminate batch job (Y/N)? y
