Hi all,
I’m looking for a way to define task order in the pipeline collumn view on the Sequence page.
It doesn’t seem to respect the Task order value…
Any ideas how to force it to respect task order value?
cheers!
Hi @pascal.laq
Welcome to the forums!
I’m going to move this over to our Shotgun category, hopefully you’ll get a response there.
Phil
If I understood correctly, I have the same problem, I sorted my tasks with the column sort order and configured the upstream and downstream dependencies, but it does not respect the order in my shot page
I think you need to add the Sort Order field in each Pipeline Step group, and right-click on Sort Order to set the sorting. Then you can hide Sort Order if you want
