Hey @Ricardo_Musch sorry this dropped off our radar.
As far as I know, the engine does not have a recognized frameworks section.
The engine or apps may require the frameworks in their info.yml files.
But if you have the framework defined in the environment files under the frameworks section
then you can import it in an app or engine hook.
Since the framework can’t be called from a core hook, I’m not sure if a framework approach will work for you here.
