I was wondering if I could get a bit of a sanity check when it comes loading/using frameworks within engines.
I’m currently trying to load and use a custom framework within existing engines (tk-maya and tk-houdini) (not in an app or hook).
I’ve been able to do so if I add the framework as a dependency to the engine’s info.yml and use:
sgtk.platform.current_engine().frameworks[].import_module().
Is there a way I can use this method without having to edit the existing engine’s info.yml?
Am I able to add this to the dependencies another way on the fly?
As I’d like to avoid having to run custom tweaked engines.
Is there a better way to go about doing this?
Thanks for any help/advice!
