Keyboard Shortcuts incompatible with international layouts
Hello all,
We’re finding impossible setting in/out points via keyboard (this actually also happens in RV) since the Spanish layout to write the square brackets is an alt/option+key type of command and it doesn’t get recognized by neither the review tool nor RV itself as the hotkey.
Since RV is not widely used in our studio, that’s not much of a concern there, but we’re testing the grounds to switch from the legacy review tool to the new one and this is one of the things that we’re encountering right now to be a bit of a pain point since the cuts functionality doesn’t consider a mini-cut option as the original cuts tray did.
Cheers!
Copy that, I will log a bug ticket and push this through as soon as we can. Thank you for logging this!
