How am I supposed to use engine.show_modal?
When I click a button connected to either the dialogs accept or reject signals my dialog disappears but the window and shotgun banner are still there.
from Qt import QtWidgets, QtGui, QtCore
class Dialog(QtWidgets.QDialog):
def __init__(self):
super(Dialog, self).__init__()
self.build_ui()
self.resize(250, 150)
def build_ui(self):
layout = QtWidgets.QVBoxLayout()
self.setLayout(layout)
text = QtWidgets.QLabel('message')
text.setAlignment(QtCore.Qt.AlignHCenter | QtCore.Qt.AlignVCenter)
layout.addWidget(text)
h_layout = QtWidgets.QHBoxLayout()
yes_button = QtWidgets.QPushButton('yes')
no_button = QtWidgets.QPushButton('no')
no_button.setDefault(True)
yes_button.clicked.connect(self.accept)
no_button.clicked.connect(self.reject)
h_layout.addWidget(yes_button)
h_layout.addWidget(no_button)
layout.addLayout(h_layout)
print engine.show_modal('Test', engine, Dialog)
I couldn’t get this to work. I’ll just give up on the shotgun banner and manage the dialog myself.
Hi @jhultgre
I just mocked up a basic app here and replicated what you are seeing. I think the issue is that the QDialog widget doesn’t call close:
I got it to work by overriding the reject and accept methods and calling close in them.
Here is my basic app code:
from sgtk.platform import Application
from sgtk.platform.qt import QtGui, QtCore
class Dialog(QtGui.QDialog):
def __init__(self):
self.build_ui()
def build_ui(self):
layout = QtGui.QVBoxLayout()
text = QtGui.QLabel('message')
h_layout = QtGui.QHBoxLayout()
yes_button = QtGui.QPushButton('yes')
no_button = QtGui.QPushButton('no')
def reject(self):
super(Dialog, self).reject()
self.close()
def accept(self):
super(Dialog, self).accept()
self.close()
class StgkStarterApp(Application):
def init_app(self):
self.engine.register_command("Show Starter Template App...", self.show_app)
def show_app(self):
print self.engine.show_modal('Test', self, Dialog)
Given that we’re discussing Dialog boxes and not app UI…
Pros of using engine.show_modal:
- Integrated with look of SgTk
- Integrated with the host DCC’s windows
- Closed when bundle / app is destroyed
It is a fair bit of code though, as @philip.scadding 's example above shows. Compare to this:
def warning_dialog(bundle, title, text):
box = QtGui.QMessageBox(
QtGui.QMessageBox.Warning,
title,
text,
parent=bundle.engine._get_dialog_parent()
box.show()
box.raise_()
box.exec_()
The brevity of PySide’s QMessageBox static methods are preferable, but there isn’t a way to hint those to appear on top(?)
