Hi I think I am hitting a bug, and I am unclear why it’s popping up.
It looks like when I have only 1 shot and that shot is missing a task template this triggers maybe?
I’m not 100% sure on the cause, hopefully someone here can give me a hand if it’s obvious on your side.
Basically the shotgun_model that is returning data for the File Open form is hitting a KeyError and crashing nuke.
The location of the KeyError is here: tk-framework-shotgunutils/master/python/shotgun_model/shotgun_model.py
Here is the traceback:
File "/opt/shotgun_cache/dpoe/archplatform/p124c1.basic.desktop/cfg/install/core/python/tank/platform/engine.py", line 1685, in _create_widget
widget = derived_widget_class(*args, **kwargs)
File "/opt/shotgun_cache/dpoe/bundle_cache/app_store/tk-multi-workfiles2/v0.12.3/python/tk_multi_workfiles/file_open_form.py", line 47, in __init__
FileFormBase.__init__(self, parent)
File "/opt/shotgun_cache/dpoe/bundle_cache/app_store/tk-multi-workfiles2/v0.12.3/python/tk_multi_workfiles/file_form_base.py", line 70, in __init__
self._entity_models = self._build_entity_models()
File "/opt/shotgun_cache/dpoe/bundle_cache/app_store/tk-multi-workfiles2/v0.12.3/python/tk_multi_workfiles/file_form_base.py", line 241, in _build_entity_models
bg_task_manager=self._bg_task_manager,
File "/opt/shotgun_cache/dpoe/bundle_cache/app_store/tk-multi-workfiles2/v0.12.3/python/tk_multi_workfiles/entity_models/extended_model.py", line 71, in __init__
entity_type, filters, hierarchy, fields, *args, **kwargs
File "/opt/shotgun_cache/dpoe/bundle_cache/app_store/tk-framework-shotgunutils/v5.7.6/python/shotgun_model/shotgun_entity_model.py", line 84, in __init__
self._load_data(entity_type, filters, hierarchy, fields)
File "/opt/shotgun_cache/dpoe/bundle_cache/app_store/tk-framework-shotgunutils/v5.7.6/python/shotgun_model/shotgun_model.py", line 386, in _load_data
None, root, self._create_item
File "/opt/shotgun_cache/dpoe/archplatform/p124c1.basic.desktop/cfg/install/core/python/tank/log.py", line 514, in wrapper
response = func(*args, **kwargs)
File "/opt/shotgun_cache/dpoe/bundle_cache/app_store/tk-framework-shotgunutils/v5.7.6/python/shotgun_model/data_handler.py", line 272, in generate_child_nodes
factory_fn(parent_object, data_item)
File "/opt/shotgun_cache/dpoe/bundle_cache/app_store/tk-framework-shotgunutils/v5.7.6/python/shotgun_model/shotgun_model.py", line 622, in _create_item
self._update_item(item, data_item)
File "/opt/shotgun_cache/dpoe/bundle_cache/app_store/tk-framework-shotgunutils/v5.7.6/python/shotgun_model/shotgun_model.py", line 660, in _update_item
{"name": data_item.field, "value": data_item.shotgun_data[data_item.field]},
KeyError: 'entity.Shot.sg_sequence.Sequence.episode'
