Flow Production Tracking Integration v1.7 Release Notes
v1.7.1
What’s Changed
  • Add custom actions for Breakdown2 in VRED
  • Scene Builder App for Alias and VRED
  • Update Mari software path to version 7
  • Add custom hook for 3ds Max to style Workfiles App
  • Remove 3dsmaxplus
  • Update MotionBuilder 2025 path
  • Include Data Validation in Maya
Toolkit component versions
Updated tk-framework-qtwidgets to v2.12.2
  • Fix Qt6 on Mac closing multi workfiles2 makes maya 2025 crash
  • New feature to allow filter menu to be docked.
  • Syntax updates for PySide6. Requires core v0.21.4.
  • PySide and Qt4 code cleanup.
Updated tk-framework-shotgunutils to v5.10.0
  • Pyside and Qt4 code cleanup
Updated tk-multi-publish2 to v2.9.0
  • Fix the Checkboxes in the Publish Window. Detected on Maya 2025 (Qt6)
  • Add support for Datetime objects as PublishSetting type
  • Allow publishing to templates from Standalone (requires config setting)
  • Bug fix to handle case when property is None.
  • Upload Version plugin now includes .avi files
  • Add tutorial to create new publish plugin (docs)
Updated tk-core to v0.21.6
  • Add shiboken module to tk core qtimporter class
  • Fix compatibility with PySide6 by patching QCoreApplication.flush()
  • Fix authentication method UI selector wrong behavior when using SGD 1.5/PySide/Qt4
  • Fix wrongly submitted TK_SHOTGRID_SSO_DOMAIN variable by sanitizing the URL
  • Add missing legacy login/password authentication in console mode
  • Stop masking SSL related exceptions
  • Add default argument to anonymous function (Qt6 patcher)
  • Add missing import TankGitError
  • Patch QIcon.pixmap method to be compatible with PySide6.
  • Make the QtImporter logic easier to read.
  • Initialize the dark look and feel for Qt6.
  • Bump python-api to v3.6.1. This includes a nice contribution to python-api’s Mockgun thanks to slingshotvfx.
  • Flip the arrow icon when “Click for app details”.
Updated tk-multi-loader2 to v1.25.1
  • Improve API and support new config option ‘All’ for actions.
  • Handle exception on Qt6
Updated tk-desktop to v2.7.3
  • Add a banner to announce the end of support for CentOS 7.
  • Remove the banner about the end of support for Python 2.
  • Fix blank panel when the config does not define any actions.
Updated tk-maya to v0.13.1
  • Add support for Maya 2025
  • Support Data Validation App for Maya
Updated tk-alias to v3.3.1
  • Support Alias 2025 & add custom actions for Alias Breakdown2.
  • Update Data Validation UI based on Alias events.
  • Fix running engine in headless mode.
Updated tk-vred to v3.4.0
  • Add custom actions to VRED Breakdown2 and bug fix.
  • Fix importing multiple files at once.
  • Update Data Validation UI based on VRED events.
Updated tk-framework-alias to v1.4.1
  • Update Alias Python Plugin and API
  • Expose start up method and fix typo
Updated tk-nuke to v0.15.1
  • Add support for Nuke 15
Updated tk-3dsmax to v1.4.0
  • Add support for 3ds Max 2024
  • Fix Workfiles App style
  • Add support to the new menu system introduced on 3dsmax 2025
Updated tk-houdini to v1.9.1
  • Fix infinite loop for multiple panels
Updated tk-framework-adobe to v1.2.2
  • Update idna to 3.7
Updated tk-framework-desktopserver to v1.7.1
Updated tk-multi-data-validation to v0.3.0
  • New progress bar that will run during validation or fix operations
  • New hook option to allow updating the app based on DCC events
Updated tk-aftereffects to v0.4.1
Updated tk-photoshopcc to v1.11.0
Updated tk-shell to v0.10.1
Updated tk-multi-pythonconsole to v1.4.1
Updated tk-multi-launchapp to v0.13.1
  • Escape HTML characters for show_generic_error_dialog().
Updated tk-flame-review to v1.5.1
  • Fix gray artifact on FPTR icon
Updated tk-flame-export to v1.11.1
Updated tk-multi-breakdown2 to v0.4.0
  • Add custom actions to file items defined by the config
  • Filters can be docked in left side panel
  • Add config setting to filter publish history
Updated tk-mari to v1.4.1
  • Add support for Mari 7
Updated tk-multi-demo to v1.5.0
  • Adds support to PySide6 while dropping support for PySide1
Updated tk-motionbuilder to v0.8.0
GitHub links
v1.7.2
What’s Changed
  • Add new major version for tk-framework-alias
  • Fix python console name to match the app name
Updated tk-3dsmax to v1.4.1
Drop Python 2 compatibility - part 1
Updated tk-aftereffects to v0.4.4
Remove CC from product name
Remove compatibility with Python 2 (part 1)
Fix placeholder text style for Qt6
Updated tk-alias to v4.0.0
  • Performance update and support Python 3.11 and PySide6
Details
  • Improve Data validation performance
  • Add config setting for data validation max error display
  • AliasPy module updates
  • Update documentation
  • Bump minimum required version for tk-framework-alias v2.0.0
Updated tk-core to v0.21.7
  • Bump python-api to v3.6.2
  • Remove compatibility with Python 2 (part 1)
  • New YML build UI resources
Updated tk-desktop to v2.7.5
  • Prevent flaky tests
  • Create a banner to announce the end of support for Python 3 7 and SGD 1.7
  • new import for ensure_* functions
  • New build resources yml
  • Use Enum for pyside2/6
  • Standardize osutils
Fix QDialog Enum
Updated tk-flame to v.19.2
Fix Flame 2025.1 project creation
New Build resources
New Build resources
Updated tk-flame-review to v1.5.2
New build resources
New build resources
Updated tk-framework-adminui to v0.7.7
  • Use QTextCursor Enum for Qt6
  • New build resources YML
Updated tk-framework-adobe to v1.2.4
  • Update requests to 2.32.2 because 2.32.0 was yanked
  • Separate Bundles
  • Remove CC from product name as far as possible
  • Update certifi to 2024.7.4
  • import six replaced by sgutils for ensure_* funcs
  • Add Python 3.11 modules
Updated tk-framework-desktopclient to v0.3.4
Updated tk-framework-desktopserver to v1.7.3
  • Update setuptools to 70.0.0
  • Improve error handling
Updated tk-framework-qtwidgets to v2.12.4
  • Update required tk-framework-shotgunutils version
  • Improve note input widget UI
  • Update README: ShotGrid to Flow Production Tracking (Thanks to @sungbinlee)
  • first phase python2 dropping
  • new build resources yml
  • Don’t use ensure_str to prevent crashing
Updated tk-framework-shotgunutils to v5.10.1
  • Drop Python 2 compatibility - part 1
  • New Qt UI resource process
Updated tk-framework-widget to v1.2.1
  • Fix PNG profile to prevent incorrect sRGB warning
Updated tk-houdini to v1.9.3
Create the use_short_menu_name setting & Remove Python 2 compatibility
As of version 20.5.368, Houdini 20.5 is supported.
Updated tk-mari-projectmanager to v1.4.1
Updated tk-maya to v0.13.2
Rename the use_sgtk_as_menu_name setting to use_short_menu_name
Updated tk-motionbuilder to v0.8.2
Remove Python 2 compatibility - part 1
Fix placeholder style for Qt6.
Updated tk-multi-about to v0.5.1
Clean-up Azure flags and new build_resources.yml configuration.
Updated tk-multi-bg-publish to v0.2.1
Bug fix to get the engine after bootstrapping
Updated tk-multi-breakdown to v1.9.1
Run mogrify to strip the problematic profiles and new build_resources.yml configuration.
Updated tk-multi-breakdown2 to v0.4.2
  • Add config option to specify reference update requires user interaction
  • Six.py str types removed
Updated tk-multi-data-validation to v0.3.1
  • Option to turn on/off auto-refresh feature
  • Allow detail items to be multi-selected and perform bulk actions
  • Improve error handling and display critical errors more visibly
Updated tk-multi-demo to v1.5.1
  • Six.py str types removed, new build_resources.yml configuration.
Updated tk-multi-devutils to v1.3.1
Updated tk-multi-launchapp to v0.13.2
  • Run mogrify to strip the problematic profiles
Updated tk-multi-loader2 to v1.25.2
  • First phase Python 2 removing
Updated tk-multi-publish2 to v2.10.1
  • Support publishing ICEM file types in standalone publisher
Updated tk-multi-pythonconsole to v1.4.2
Updated tk-multi-screeningroom to v0.6.1
First phase of Python2 removing
Updated tk-multi-setframerange to v0.6.1
Updated tk-multi-shotgunpanel to v1.9.1
  • Fix RGB CSS warning
  • Fixup blank home icon when FPTR user has no thumbnail defined
Updated tk-multi-snapshot to v0.10.1
  • first phase python2 removing
Updated tk-multi-workfiles2 to v0.15.2
New build resources
Updated tk-nuke to v0.15.3
Add support to Nuke 15.1
Updated tk-nuke-quickreview to v1.3.1
Updated tk-nuke-writenode to v1.7.1
Remove duplicate category for tab-bar which breaks due to Nuke’s 50 character limit
Updated tk-photoshopcc to v1.11.3
Remove CC from product name. Run mogrify to strip the problematic profiles.
Updated tk-shotgun to v0.11.1
Drop Qt4 compatibility - part 1
Updated tk-vred to v3.4.1
Bug fixes and update minimum supported VRED version
Details
  • Fix breakdown hook
  • Ensure panel app is visible on open
  • Show progress dialog when importing files async
  • Update min supported logic to avoid dialog pop up
GitHub links
v1.7.3
What’s Changed
  • Clean up deprecated Azure Pipelines
Updated tk-aftereffects to v0.4.5
  • Change the way the dialogs are closed when destroying the engine
Updated tk-alias to v4.1.3
  • Bug fix for running Background Publishing in Alias.
  • Fix Alias Engine to properly shutdown.
  • Add new publish option Export Selection
  • Improve Alias Engine start up
Updated tk-core to v0.21.8
  • Make the “Forgot your password” link visible only when using legacy authentication
Updated tk-desktop to v2.7.7
  • Fix MacOS missing dock icon for v1.9 and lower
  • Fix a grammar error in the first-launch notification banner.
Updated tk-flame to v1.19.3
  • Improve multi-version support for user creation
Updated tk-flame-export to v1.11.2
  • New way to build resources according to tk-toolchain::tk-build-qt-resources - PySide2
  • Drop compatibility with Python 2
Updated tk-flame-review to v1.5.4
Updated tk-framework-adobe to v1.2.7
  • New env variable SHOTGUN_ADOBE_SERVER_PING_TIMEOUT allows us to initialize the Node server with a higher pingTimeout, this defines how often the server sends a “ping” to the client to check that the connection is still active
  • Use TK Core logic to check if PySide is available in the environment instead of depending on direct PySide imports. This creates a more maintainable code across PySide versions.
  • The Panel JS closes correctly after the Manager JS is closed.
Updated tk-framework-alias to v2.1.1
  • Support Alias 2025.1 and improve Alias plugin start up.
  • Performance and resiliency improvements.
  • Increase server timeout for Alias API calls
  • Improve performance on batch Alias API calls
  • Improve framework initialization time
  • Handle client disconnect more gracefully
  • Bug fix to set client timeout
  • Update python packages
Updated tk-framework-desktopserver to v1.7.6
  • Updates cryptography to 43.0.1
  • Updates pyOpenSSL to 24.2.1 (required for cryptography)
  • Fixes CVE-2024-6119
  • Fixes CVE-2024-4603
  • Fixes CVE-2024-2511
  • Package Python modules
  • Upgrade Twisted to 24.10.0
Updated tk-framework-qtwidgets to v2.12.5
  • Adds a preset filter feature to the filter menu widget.
Updated tk-maya to v0.13.3
  • Support minimize button for Toolkit dialogs on Maya for Windows.
  • To enable this feature, use enable_dialogs_minimize_button settings in tk-maya.yml config file
Updated tk-multi-screeningroom to v0.6.2
  • Fix import syntax that could lead to bugs on file screeningroom.py
Updated tk-multi-shotgunpanel to v1.9.2
  • Adds a filter presets feature. Filter presets pre-defined in the configuration can now be toggled on or off in the UI and allow for more complex server-side filtering.
  • Adds the ability to configure which sort fields appear in the Tasks tab sort menu.
Updated tk-multi-workfiles2 to v0.15.4
  • Fix PySide UI sources
  • The context cache (_CONTEXT_CAHE) updates correctly after saving a file.
Updated tk-nuke-quickreview to v1.3.2
Updated tk-nuke-writenode to v1.7.2
Updated tk-photoshopcc to v1.11.5
  • Make sure the widgets are properly deleted to avoid orphaned python processes when closing Photoshop on MacOS.
  • The context (_CONTEXT_CACHE) is now correctly updated and available after saving or publishing a document.
Updated tk-shotgun-launchpublish to v0.7.1
  • The import for urllib has changed, removing the dependency on six and Python 2.
Updated tk-shotgun-launchvredreview to v1.2.1
  • Clean up deprecated Azure Pipelines flags.
GitHub links
v1.7.4
What’s Changed
Updated tk-3dsmax to v1.4.2
Removed Python 2 code.
Updated tk-alias to v4.1.6
  • Dynamic Alias installation hard drive letter lookup.
  • Fix proxy server handling and improve loader action performance
  • Removed Python 2 code.
Updated tk-core to v0.22.2
  • Formalize the end of CentOS support.
  • Python API can use a custom CA Cert store using the SHOTGUN_API_CACERTS variable. App Session Launcher uses a different API and was using a different CA Cert store. It is now aligned with python-api (certifi).
  • Update python-api from v3.6.2 to v3.8.1. Enables payload optimization by default.
  • Sync Unknown Events metrics. Differenciate desktop engine metrics.
  • Add support to PySide6 for availableGeometry. Handle AttributeError.
  • Update pre-commit hook versions.
  • Minor improvement in pre-commit configuration file.
  • Update repository badges.
  • PySide/Qt4 is no longer supported.
  • Update python-api to v3.8.2, which prevents a flaky disconnection when uploading thumbnails on publish.
Updated tk-desktop to v2.7.10
  • Fix about box / licenses encoding bug that happened on some versions of desktop on macOS.
  • Remove CentOS 7 End Of Support outdated banner.
  • Update Software Credits.
  • Update license HTML.
  • Refactor __launch_app_proxy_for_project in a QThread.
  • The prefix ‘v’ was added to ensure correct version comparison in the uses_legacy_authentication() function.
Updated tk-desktop2 to v1.6.1
Updated tk-flame to v1.19.5
Support project creation when no volume is configured
Updated tk-flame-export to v1.11.3
  • Fix FLME-66887 - Add back call to update_version_dependencies
Updated tk-framework-adminui to v0.8.0
Updated tk-framework-adobe to v1.2.10
  • Requirements for pkgs.zip updated.
  • Certifi upgrade to 2024.12.14.
  • Hook for socketIO prepare_http_session.
  • Env var to enable proxy.
Updated tk-framework-alias to v2.1.4
  • Add Alias API async functionality
  • Add handling for proxy servers
  • eventlet updated to 0.38.0 for python 3.7 requirements.
  • idna updated to 3.10 for python 3.7 requirements.
  • certifi updated to 2025.1.31.
  • typing-extensions package renamed.
Updated tk-framework-desktopclient to v0.4.0
  • Package the Python third parties as ZIP.
  • Bump websocket-client version to 1.6.1 (last version that supports Python 3.7).
  • Remove Python2-specific syntax.
Updated tk-framework-desktopserver to v1.8.2
  • This version was tagged before as v2.0.0 by mistake.
  • Certifi package updated to 2024.12.14 for each python version
  • Update old PySide (1) syntax for method setResolveSymlinks. This causes a bug when clicking on browse file for File/Link fields on FPTR web.
  • Fix Apple Silicon binaries that were not included in the previous release.
  • Update pre-commit black hook to 25.1.0
Updated tk-framework-qtwidgets to v2.12.6
Updated tk-framework-shotgunutils to v5.10.2
Updated tk-houdini to v1.9.4
Updated tk-mari to v1.4.2
Updated tk-maya to v0.13.4
Updated tk-motionbuilder to v0.8.3
Updated tk-multi-about to v0.5.2
Updated tk-multi-breakdown2 to v0.4.3
Updated tk-multi-data-validation to v0.3.2
Updated tk-multi-demo to v1.5.3-beta.4
  • Test PoC for release notes
Updated tk-multi-launchapp to v0.13.4
  • Improved metrics collection.
Updated tk-multi-publish2 to v2.10.3
  • Add UI option to turn on/off Background Publishing (when supported)
Updated tk-multi-pythonconsole to v1.4.3
Updated tk-multi-reviewsubmission to v1.3.1
Updated tk-multi-setframerange to v0.6.2
Accurately get the frame range from site to Houdini.
Updated tk-multi-workfiles2 to v0.15.5
Updated tk-nuke to v0.15.5
Reverts Hiero log level after emitting a log message. Thanks to @reformstudios
Updated tk-photoshopcc to v1.11.6
Updated tk-shell to v0.10.2
Updated tk-vred to v3.5.1
Improvements, bug fixes, new developer docs
Details
  • New Loader2 action to import environments
  • Update FPT Desktop find VRED software routine for Windows 11
  • Fix FPT Panel Create Smart Reference action
  • Remove Python 2 support
  • New developer docs https://developers.shotgridsoftware.com/tk-vred/
Github Links
