A new version of tk-config-basic has been released!
See the complete release notes.
v1.7.5
What's Changed
  • Added new file handling for NX File (.prt) (#137) (SHOT-4439)
  • Updated VRED actions for loader and panel (#138)
  • Added Photoshop PNG and JPG publish plugins (#139) (SG-27509)
Toolkit Component Versions
Updated tk-3dsmax to v1.4.4
  • Added support for 3ds Max 2026 (#48)
  • Fixed winreg import error (#47)
  • Reviewed and unified code handling for supported DCC versions (SG-32814)
Updated tk-aftereffects to v0.4.6
  • Added support for After Effects 2025 (#59)
  • Fixed broken in-app tests (#58)
Updated tk-alias to v4.1.9
  • Updated minimum supported version for Alias 2026.0
  • Supported Alias Learning Edition #216
  • Blocked publish export selection if nothing is selected #217
  • Fixed loader actions in Alias #218
Updated tk-core to v0.22.4
  • Prevented QtImporter from raising an exception if QtWebEngine is not available
  • Added RV Live Review metrics
  • Fixed web login not working with PySide2
  • Removed code related to QtWebKit since Qt4 is no longer supported
  • Replaced deprecated utcnow() function
  • Bumped python-api to v3.8.4
Updated tk-desktop to v2.7.12
  • Removed dead authentication code
  • Hooked PreInitialization to ensure early initialization tasks during bootstrap
  • Ensure datetime objects are initialized in naive mode
Updated tk-flame to v1.19.6
  • Handled snapshot export
Updated tk-framework-alias to v2.2.2
  • Updated Alias Python Plugin to v4.1.0 to support 2026.0
  • Updated Alias Python API to v6.0.0 to support 2026.0
  • Increased server max HTTP buffer for Alias API requests
  • Added API reference docs for Alias 2026
  • Added OpenModel Alias Python API files for supported Alias and Python versions
  • Improved exception handling in Alias #93
Updated tk-framework-desktopserver to v1.8.3
  • Updated cryptography to 44.0.1
Updated tk-framework-shotgunutils to v5.10.3
  • When using ShotgunModel._refresh_data() to refresh the data model, only the first column was refreshed, while the documentation stated that a full rebuild of the model should be issued. Now, when new data arrives, it discovers the rest of the items on the same row (siblings) and updates their text if needed.
  • Addressed flaky tests with the latest PySide6
Updated tk-houdini to v1.9.6
  • Updated supported versions of Houdini (#80)
Updated tk-maya to v0.13.6
  • Added support for Maya 2026 (#121)
Updated tk-multi-launchapp to v0.13.5
  • Improved experience for MotionBuilder (SG-32814)
Updated tk-multi-publish2 to v2.10.4
  • Set the text format on the description box so Qt will strip whitespace even if no HTML tags are present
Updated tk-nuke to v0.15.7
  • Added support for Nuke 16 (#115)
  • Replaced mock (#113)
  • Removed YAML deprecation warning (#114)
Updated tk-photoshopcc to v1.11.9
  • Added support for Photoshop 2025 (v26)
  • Quick fix for RuntimeError: Internal C++ object (TankQDialog) already deleted. Thanks to @kogi18
  • Fixed RPC propagation for log messages
  • Allowed export plugin to be used in basic configuration (SG-27509)
  • Fixed Windows-specific regression when using multiple widgets (SG-39324)
Updated tk-vred to v3.5.4
  • Updated minimum supported version to 2026 by @staceyoue in #133
  • Supported VRED Learning Edition #135
  • Updated VRED actions #136
v1.7.6
FPTR Basic Configuration v1.7.6 Release
What's Changed in Toolkit component versions
Updated tk-3dsmax to v1.4.6
  • Use unittest.mock instead of deprecated mock third party library.
  • Removed try/except sgutil blocks and ensure_ methods.
Updated tk-aftereffects to v0.4.7
  • SG-39698 Removed try/except sgutils block in #60
Updated tk-alias to v4.2.1
  • New engine hook for Alias Api Extensions
  • Bump tk-framework-alias minimum version to v2.3.0
Updated tk-core to v0.23.1
  • Add support for QtWebEngineWidgets in tk-core qt wrapper (SG-39733)
  • Fix an issue where it was not possible to use ToolkitManager to bootstrap an engine if tk-core was installed using pip (SG-9141)
  • Remove Python 2 code (SG-38307)
  • FIx an issue where the package version was wrong when installing using a package manager (SG-40146)
  • We copied the ensure_binary and ensure_str functions from the python-api and added a deprecation warning because these functions are going to be decommissioned soon. These functions are gone in the python-api v3.9.0. (SG-39698)
  • Removed primary dependence on distutils package since it's not supported by Python 3.12. This is a preparation step for VFX 2026. We first try to use packaging.version instead and fall back to distutils for older versions of Python. (SG-36372)
  • Replaced imp module with importlib since it's not supported by Python 3.12. This is a preparation step for VFX 2026. (SG-15664)
  • Bump ruamel.yaml to 0.18.14. The previous version depended on the distutils package. (SG-39809)
  • Bump python-api to v3.9.0. This now includes the Python 2 removal.
  • Remove excessive warning logging related to DCC version comparisons
  • Restore linux2 keys to fix regression with Advanced Project Setup wizard
Updated tk-desktop to v2.8.0
  • Removed dependence on ensure_binary and ensure_str. Removed dependence on sgutils package. (SG-39698)
  • Fix CI issue caused by the latest tk-core release. (SG-40311)
Updated tk-flame to v1.19.7
  • Add the order tag to Flame menu command to preserve the order
  • Split UI for pre/post 2026 project creation
Updated tk-framework-adminui to v0.8.1
  • Fixup regression with Linux fields being invisible introduced by tk-core v0.22.6
Updated tk-framework-adobe to v1.2.11
  • Removed try/except sgutil blocks and ensure_ methods in #90
  • New CEP plugin - fixing ZXP sign issue in #92
Updated tk-framework-alias to v2.3.1
  • Alias Python API updated for 2026.0
  • Added Alias Python API Extensions capabilities
  • Security updates to python packages
  • Use super() instead of an explicit call to the parent function.
Updated tk-framework-desktopclient to v0.4.3
  • Updated pre commit hook versions.
  • Removed sgutils missed (SG-39698).
  • Ensure binary send and recv (SG-39698).
Updated tk-framework-desktopserver to v1.8.5
  • Resolved a GLIBC version incompatibility that affected web integration on Enterprise Linux 8 (SG-39655 - PRs #298 and #299)
  • Removed try/except sgutil blocks and ensure_ methods (SG-39698).
Updated tk-framework-qtwidgets to v2.12.8
  • Replaced mock in #175
  • Removed try/except sgutils block in #176
  • Fixed Python 2 code removal regression - SQLite payload is binary, not text (SG-40361 in PR 177).
Updated tk-framework-shotgunutils to v5.11.1
  • Removed dependence on ensure_binaryandensure_str. Removed dependence onsgutils package. (SG-39698)
  • Fixed Python 2 code removal regression - 'str' object has no attribute 'decode' in UserSettings (SG-40414 in PR 170).
Updated tk-houdini to v1.9.9
  • Remove unused Python third party libraries related to Python 2 support (SG-40135 - PR #85)
  • SG-39698 Removed try/except sgutils block in #83
Updated tk-multi-data-validation to v0.3.3
  • Fixed an issue where the app froze when trying to run the fix action for a rule with dependencies (SHOT-4564).
Updated tk-multi-launchapp to v0.14.0
  • Switch distutil.version to packaging.version since it's not supported by Python 3.12. This is a preparation step for VFX 2026. We first try to use packaging.version instead and fall back to distutils for older versions of Python. (SG-36372)
Updated tk-multi-loader2 to v1.25.3
  • Removed try/except sgutils block in #125
Updated tk-multi-publish2 to v2.10.5
Updated tk-nuke to v0.16.0
  • Removed dependence to ensure_binary and ensure_str. Removed dependence onsgutils package. (SG-39698)
  • Skip unit tests for Nuke versions lower than 10. This happened because of the distutils removal on tk-core. (SG-40319)
Updated tk-photoshopcc to v1.12.0
v1.7.7
FPTR Basic Configuration v1.7.7 Release
Updated tk-3dsmax to v1.4.8
  • Fix testing instructions not working on Max versions 2026 & 2022 (SG-38773 - PR #55)
  • Support for 3ds Max 2027 (SG-42790 - PR #56)
  • Fix FPTR menu not loading in 3ds Max 2027 with tk-config-basic (SG-42906 - PR #57)
Updated tk-aftereffects to v0.4.8
  • Removed outdated references (SG-39031 - PR #62)
  • Support After Effects v26 (SG-42300 - PR #64)
Updated tk-alias to v4.4.0
  • Bump minimum framework version for 2026.1 support (PR #222)
  • Fix changing the context when file opened through Alias
  • Bump dependency tk-framework-aliastranslations to v0.3.1
  • Bump dependency tk-framework-alias version to v2.5.0
  • Fix getting context (SHOT-4580 - PR #229)
  • Update for Python 3.13
  • Fix: Importing a file does not overwrite the current construction options
  • Drop support for Alias 2023
  • Support Alias 2027 for Python 3.11 and 3.13
Updated tk-core to v0.23.8
  • Introduce new approach for Python third-party dependencies (SG-37222 - PR #996)
  • Add deprecation warnings for Python versions < 3.9 (SG-39039 - PR #1024)
  • Improve comments about compatibility with fw-adminui prior to v0.8.1 (SG-40476 - PR #1058)
  • Disable automatic PySide imports (SG-39029 - PR #1061)
  • Add deprecation warnings for six.py and sgutils.py (SG-40715 - PR #1063)
  • Replace legacy version parsing with packaging.version and add normalize_version_format() (SG-40319, SG-41241 - PR #1066)
  • Improve Git URI detection mechanism (SG-39455 - PR #1067)
  • Update deprecation warning for Python 3.7 end of compatibility (SG-40994 - PR #1069)
  • Bump python-api to v3.9.1 (PR #1072)
  • Fix Python 3.7 typing compatibility in util.py (SG-41301 - PR #1073)
  • Prevent tk component autoupdate (SG-40996 - PR #1077)
  • Update shotgun python-api to v3.9.2 (SG-35561 - PR #1078)
  • Remove outdated references of PySide/Qt4 (SG-39031 - PR #1079)
  • Add support for VFX CY2026 - Python 3.13 - Qt 6.8 (SG-40980 - PR #1080)
  • Fix deprecation warnings for QTextCodec.setCodecForCStrings() (SG-41647 - PR #1083)
  • Fix missing __init__.py in ruamel module (SG-41902 - PR #1087)
  • Fix FileNotFoundError being raised incorrectly (SG-40807 - PR #1088)
  • Make website-originated context available in FPTR menu (SG-41800 - PR #1089)
Updated tk-desktop to v2.8.5
  • Enhance deprecation banner for Python 3.7 end-of-life (SG-40994 - PR #206)
  • Fix macOS system tray regression in PySide6 (SG-41259 - PR #207)
  • Update outdated references (SG-39031 - PR #208)
  • Remove unused PySide1 generated files (SG-41634 - PR #209)
  • Fix data persistence issue after re-authentication (SG-39788 - PR #211)
  • Load osutils from app bundle via sys.prefix (SG-42559 - PR #212)
  • Update VFX Reference Platform and Python badges (SG-42807 - PR #214)
  • Update About Box - Add PySide6 (Version 6.8.3) license attribution (SG-42871 - PR #216)
Updated tk-desktop2 to v1.6.2
  • Remove try/except sgutil blocks and ensure_ methods (SG-39698 - PR #46)
Updated tk-flame to v1.19.10
  • Update Support URL (SG-40165)
  • Fix loading setup from Flow with custom named batch Reels
  • Remove outdated PySide/Qt4 references (SG-39031 - PR #159)
Updated tk-framework-adminui to v0.8.3
  • Drop compatibility with tk-core versions before v0.22.6 (SG-40476)
  • Make UI consistent with tk-core v0.23.4 Git URL detection mechanism (SG-41079)
  • Update VFX Reference Platform and Python badges (SG-42807 - PR #56)
Updated tk-framework-adobe to v1.2.12
  • Update "requests" package to 2.32.5 (SG-39341 - PR #94)
  • Add support for VFX CY2026 - Python 3.13 - Qt 6.8 (SG-40981 - PR #101)
  • Upgrade certifi from 2024.12.14 to 2026.1.4 (SG-39923 - PR #103)
Updated tk-framework-alias to v2.6.0
  • Security update eventlet (PR #108)
  • Do not raise exception on API import failure (PR #109)
  • Update python-socketio package (PR #112)
  • Add Alias 2026.1 support (PR #114)
  • Security upgrade urllib3 from 2.5.0 to 2.6.0
  • Update to Python 3.11 on Alias plugin side
  • Add Alias Python API v7.0.1 for Alias 2026.1
  • Add Alias Python API v6.0.2 for Alias 2026.0
  • Python 3.13 support
  • Update python packages for security
  • Support for Alias 2027.0 for Python 3.11 and 3.13
Updated tk-framework-aliastranslations to v0.3.1
  • Clean up deprecated Azure Pipelines flags (PR #16)
  • Update Support URL (PR #17)
  • Fix importing the Alias API module (PR #18)
Updated tk-framework-desktopserver to v1.8.7
  • Change Git access to HTTPS using a Github App (SG-40595 - PR #303)
  • Upgrade certifi to 2026.1.4 (SG-39923 - PR #311)
  • Add Python 3.13 support (SG-42304 - PR #315)
  • Python 3.13 - Automated dependency resolution source + binary (SG-42304 - PR #317)
  • Automate universal binary generation for macOS on any architecture (SG-42304 - PR #326)
  • Update cryptography to 46.0.5 to address CVE-2026-26007 (SG-42118)
  • Update pyopenssl to 26.0.0 to address CVE-2026-27459 (SG-42922)
  • Add pyasn1 at 0.6.3+ to address CVE-2026-30922 (SG-42923)
Updated tk-framework-shotgunutils to v5.11.2
  • Fix Python syntax warnings related to regexp exclude character (SG-40620 - PR #172)
  • Remove outdated references to PySide1 (SG-39031 - PR #174)
  • Add support for VFX CY2026 - Python 3.13 - Qt 6.8 (SG-40980 - PR #175)
  • Fix random segfault by controlling Qt object destruction order (SG-42069 - PR #178)
Updated tk-framework-widget to v1.2.2
  • Remove old build_resources.sh (SG-37555 - PR #29)
  • Add support for VFX CY2026 - Python 3.13 - Qt 6.8 (SG-40980 - PR #30)
Updated tk-houdini to v1.9.12
  • Add Houdini 21.0 support (SG-40114 - PR #84)
  • Fix PyCObject compatibility (SG-40284 - PR #87)
  • Clean up legacy code (SG-40304 - PR #89)
  • Restore FPTR menu (SG-40163 - PR #92)
  • Skip test to avoid crashes in headless Houdini env (SG-40619 - PR #94)
  • Fix test frame range values to match Houdini global timeline (SG-40617 - PR #95)
  • Remove outdated references to PySide and Qt4 (SG-39031 - PR #97)
  • Fix context ready to be used after open file from scene hook (SG-38779 - PR #98)
Updated tk-maya to v0.13.11
  • Include default icons for the FPT menu in all operating systems (SG-38893)
  • Remove outdated references (SG-39031 - PR #126)
  • Support Maya 2027 (SG-42442 - PR #128)
Updated tk-multi-launchapp to v0.14.2
  • Add option to disable the launch indicator (SG-38952)
  • Remove old build_resources.sh (SG-37555 - PR #108)
  • Add support for VFX CY2026 - Python 3.13 - Qt 6.8 (SG-40980 - PR #109)
Updated tk-multi-loader2 to v1.25.6
  • Fix tooltip not showing when hovering an action (SG-40343 - PR #127)
  • Fix Python syntax warnings in Houdini actions hook (SG-40620 - PR #129)
  • Fix LoaderActionManager._execute_hook (SG-41525 - PR #131)
  • Fix banner text contrast on macOS in Adobe apps (SG-40910 - PR #132)
  • Add support for VFX CY2026 - Python 3.13 - Qt 6.8 (SG-40980 - PR #134)
Updated tk-multi-publish2 to v2.10.8
  • Improve summary display functionality (SG-41996 - PR #110)
  • Add support for .tex files and missing .tif extensions (SG-41995 - PR #131)
  • Fix expand indicator for items with non-task children after collection (SG-38951)
  • Fix thumbnails when publishing multiple files at once
  • Remove outdated PySide/Qt4 references (SG-39031 - PR #205)
  • Add support for VFX CY2026 - Python 3.13 - Qt 6.8 (SG-40980 - PR #209)
  • Update to use tk-build-qt-resources for resource generation (SG-41994 - PR #215)
Updated tk-nuke to v0.16.3
  • Drop compatibility with tk-core versions prior to v0.22.6 (SG-40476 - PR #123)
  • Clean up code by reverting change introduced in PR #95 (SG-40718 - PR #125)
  • Remove tests for Nuke versions below 10 (SG-40319 - PR #126)
  • Support Nuke 17 (SG-42791 - PR #129)
Updated tk-photoshopcc to v1.12.2
  • Add support for VFX CY2026 - Python 3.13 - Qt 6.8 (SG-40981 - PR #117)
  • Support v27 (SG-42298 - PR #119)
Updated tk-shell to v0.10.3
  • Remove outdated PySide/Qt4 references (SG-39031 - PR #36)
  • Add support for VFX CY2026 - Python 3.13 - Qt 6.8 (SG-40980 - PR #37)
Updated tk-shotgun to v0.11.4
  • Update outdated references (SG-39031 - PR #24)
  • Update VFX Reference Platform and Python badges (SG-42807 - PR #26)
Updated tk-shotgun-launchfolder to v0.4.1
  • Update VFX Reference Platform and Python badges (SG-42807 - PR #13)
Updated tk-shotgun-launchvredreview to v1.1.6
  • Remove old build_resources.sh and unused folder resources (SG-37555 - PR #17)
  • Update VFX Reference Platform (SG-42807 - PR #18)
Updated tk-vred to v3.5.7
  • Remove outdated PySide/Qt4 references (SG-39031 - PR #137)
  • Update minimum supported version to 2027.0
v1.7.8
Drop Python 3.7 support and update Toolkit components and integrations
What's Changed
  • Drop Python 3.7 support and set the minimum Python version to 3.9 (SG-43667 - #141)
Updated tk-core to v0.24.2
  • Remove the no-preview.jpg placeholder for a cleaner upload experience (SG-41375 - shotgunsoftware/tk-core#1093)
  • Adjust module initialization order to prevent unexpected behavior during application startup (SG-43219 - shotgunsoftware/tk-core#1092)
  • Fix a race condition that could disrupt the login process (SG-33297 - shotgunsoftware/tk-core#1095)
  • Improve path handling to reduce mismatches (SG-37743 - shotgunsoftware/tk-core#1097)
  • Fix API version detection in some pip installation scenarios (SG-42277 - shotgunsoftware/tk-core#1096)
  • Drop Python 3.7 support (SG-43667 - shotgunsoftware/tk-core#1107)
  • Preserve SHOTGUN_API_CACERTS precedence when patching shotgun_api3 certificates (shotgunsoftware/tk-core#1122)
  • Upgrade PyJWT to 2.12.0 to address CVE-2026-32597 (SG-43675 - shotgunsoftware/tk-core#1106)
  • Support unzipping long paths on Windows (SG-44086 - shotgunsoftware/tk-core#1118)
  • Update shotgun_api3 to 3.10.3 across supported Python versions (shotgunsoftware/tk-core#1123)
  • Fix cleanup of temporary Git clone directories containing read-only files (SG-43353 - shotgunsoftware/tk-core#845)
  • Fix TemplatePath.parent stripping optional bracket syntax, which could cause files to disappear from Workfiles listings (SG-38756 - shotgunsoftware/tk-core#1129)
  • Fix tank core upgrades failing with ModuleNotFoundError: yaml when upgrading from tk-core v0.23.6 or earlier to v0.23.7 or later (SG-44721 - shotgunsoftware/tk-core#1127)
  • Mask secrets in Git descriptor URLs (SG-44103 - shotgunsoftware/tk-core#1131)
Updated tk-desktop to v2.8.9
  • Fix the Windows title-bar close button being disabled (SG-41322 - shotgunsoftware/tk-desktop#219)
  • Fix duplicate application buttons after using Reload and Restart (SG-42329 - shotgunsoftware/tk-desktop#218)
  • Improve process handling during application shutdown (SG-43676)
  • Fix a CommunicationBase issue (SG-43676)
  • Drop Python 3.7 support (SG-43666)
  • Restore the missing configuration option in the project configuration dropdown (SG-45019)
  • Fix the About dialog to show the selected project's configuration (SG-43220 - shotgunsoftware/tk-desktop#213)
  • Fix missing icons for Desktop menu actions (SG-43379 - shotgunsoftware/tk-desktop#229)
Updated tk-flame to v1.19.12
  • Drop Python 3.7 support (SG-43666 - shotgunsoftware/tk-flame#161)
  • Make Flame hook signatures forward-compatible (#162)
Updated tk-framework-adminui to v0.8.4
  • Drop Python 3.7 support (SG-43665)
  • Fix PySide6 syntax that could break the UI when unpacking long paths on Windows
Updated tk-framework-adobe to v1.2.13
  • Drop Python 3.7 support (SG-43665 - shotgunsoftware/tk-framework-adobe#104)
  • Fix security vulnerabilities in urllib3, requests, and idna (SG-43679 - shotgunsoftware/tk-framework-adobe#105)
Updated tk-framework-desktopserver to v1.8.8
  • Drop Python 3.7 support (SG-30953 - shotgunsoftware/tk-framework-desktopserver#360)
  • Fix UnicodeDecodeError when reading subprocess output on Japanese Windows systems using cp932 encoding (SG-44961 - shotgunsoftware/tk-framework-desktopserver#367)
Updated tk-framework-shotgunutils to v5.11.3
  • Drop Python 3.7 support (SG-43665 - shotgunsoftware/tk-framework-shotgunutils#179)
  • Fix an AttributeError in ShotgunHierarchyModel when the first path is not loaded (SG-45127 - shotgunsoftware/tk-framework-shotgunutils#180)
Updated tk-houdini to v1.9.13
  • Drop Python 3.7 support (SG-43666 - shotgunsoftware/tk-houdini#102)
  • Add Python 3.13 startup libraries for Houdini 22 support (SG-45116 - shotgunsoftware/tk-houdini#105)
Updated tk-maya to v0.13.12
  • Add background publishing support in Maya (SG-43467 - shotgunsoftware/tk-maya#131)
  • Drop Python 3.7 support (SG-43666 - shotgunsoftware/tk-maya#129)
Updated tk-multi-loader2 to v1.25.7
  • Drop Python 3.7 support (SG-43664)
  • Fix a checkout revision migration regression
  • Fix the argument passed to get_draft_id
  • Fix the Nuke Create Read Node action (SG-44525)
  • Add a download action for Houdini Workfile entities
  • Fix Build New Scene in Nuke (SG-44523)
  • Fix contextual menus on entities (SG-44218)
  • Prevent download and Copy Reference Link actions for container assets (SG-44680)
Updated tk-multi-publish2 to v2.11.2
  • Add support for RLE-encoded TGA thumbnails and FPT uploads (SG-25367 - shotgunsoftware/tk-multi-publish2#216)
  • Isolate the publisher log handler for each dialog instance (SG-43417)
  • Support publishing Nuke FlowWrite nodes (SG-43811)
  • Update derivative data model handling (SG-43935)
  • Add background publishing support to the base publish workflow without affecting regular synchronous publishing or existing background-publishing integrations (SG-43467 - shotgunsoftware/tk-multi-publish2#230)
Updated tk-nuke to v0.16.4
  • Fix Nuke and Hiero project paths when Local Storage uses a Windows drive path such as Q:/ (SG-37411 - shotgunsoftware/tk-nuke#131)
v1.7.9
This config includes some important security updates.
What's Changed
  • Remove framework LMV v0.x.x by @carlos-villavicencio-adsk in https://github.com/shotgunsoftware/tk-config-basic/pull/145
  • Certifi and python-api modules version updates (SG-45902)
