Is it not possible to assign the same amount of days to multiple shots/asset or assign the same artist to multiple things at once? Must everything be done individually?
You should just be able to select all the fields you want to update, right click and then Edit selected.
Also note the dropdown options for how you would like to edit the fields.
Ah I see! Thank you very much. I had expected it would work like excel or Google sheets, where you just type directly.
Thanks again.
