Event Listener - Crashes on Task Deletion
Hello!
Running into an issue where if an event happens on task that is deleted before the event can be processed, it throws a NoneType error.
File “XXXX\script.py”, line 117, in tasks_approved
logger.info(task[“id”])
TypeError: ‘NoneType’ object is not subscriptable
I’d attempted to resolve this through try/except, but it doesn’t seem to be cutting the mustard.
try:
    logger.info(task["id"])
except NoneType:
    logger.info("Task deleted; bypassed.")
    return
Any recommendations would be helpful!
Oh, and if the full script is needed, I’m more or less using the tasks_approved plugin that comes with the event listener.
Copyright 2018 Autodesk, Inc. All rights reserved.
Use of this software is subject to the terms of the Autodesk license agreement
provided at the time of installation or download, or which otherwise accompanies
this software in either electronic or hard copy form.
See docs folder for detailed usage info.
import os
import shotgun_api3
def registerCallbacks(reg):
Register our callbacks.
:param reg: A Registrar instance provided by the event loop handler.
# Grab authentication env vars for this plugin. Install these into the env
# if they don't already exist.
server = os.environ["SG_SERVER"]
script_name = os.environ["SGDAEMON_TASKSAPPROVED_NAME"]
script_key = os.environ["SGDAEMON_TASKSAPPROVED_KEY"]
args = {
    "task_status_field": "sg_status_list",
    "task_status": ["fin"],
    "upstream_tasks_field": "upstream_tasks",
    "downstream_tasks_field": "downstream_tasks",
    "downstream_task_status_activate": ["wtg"],
    "downstream_task_status_active": "ip",
    "downstream_task_status_recurse": ["na"],
    "note_status_field": "sg_status_list",
    "close_notes": True,
    "closed_note_status": "clsd",
# Grab an sg connection for the validator.
sg = shotgun_api3.Shotgun(server, script_name=script_name, api_key=script_key)
# Bail if our validator fails.
if not is_valid(sg, reg.logger, args):
    reg.logger.warning("Plugin is not valid, will not register callback.")
    return
# Register our callback with the Shotgun_%s_Change event and tell the logger
# about it.
reg.registerCallback(
    script_name,
    script_key,
    tasks_approved,
    {"Shotgun_Task_Change": args["task_status_field"]},
    args,
reg.logger.debug("Registered callback.")
def is_valid(sg, logger, args):
Validate our args.
:param sg: Shotgun API handle.
:param logger: Logger instance.
:param args: Any additional misc arguments passed through this plugin.
:returns: True if plugin is valid, None if not.
# Make sure we have a valid sg connection.
try:
    sg.find_one("Project", [])
except Exception as e:
    logger.warning(e)
    return
return True
def tasks_approved(sg, logger, event, args):
Handles the logic to approve a Task and update associated entities.
:param sg: Shotgun API object handle.
:param logger: Logging object.
:param event: Event object.
:param args: Any args that have been passed in from the callback.
# Return if we don't have all the field values we need.
if not event.get("meta", {}).get("entity_id"):
    return
# Make some vars for convenience.
entity_id = event["meta"]["entity_id"]
# Re-query the Task to gather extra field values.
task = sg.find_one(
    "Task",
    [["id", "is", entity_id]],
    [args["task_status_field"], args["downstream_tasks_field"]],
# Return if no Task is found (this can happen when the Task is deleted).
if not task:
    logger.debug("Could not find Task ID %s" % entity_id)
    return
# Return if our Task isn't set to a valid task_status.
elif task[args["task_status_field"]] not in args["task_status"]:
    logger.debug(
        "Task with ID %s not set to one of %s, skipping."
        % (task["id"], args["task_status"])
    return
# Init our SG batch update list variable.
batch_updates = []
# Get downstream tasks that need to be updated.
build_updates_for_downstream_tasks(sg, logger, task, batch_updates, args)
# Find any Notes linked to the current Task and close them.
if (
    args.get("close_notes")
    and args.get("note_status_field")
    and args.get("closed_note_status")
    notes = sg.find(
        "Note",
        [["tasks.Task.id", "is", task["id"]]],
        ["tasks", args["note_status_field"]],
    for note in notes:
        if all_note_tasks_approved(sg, note, args):
            batch_updates.append(
                    "request_type": "update",
                    "entity_type": "Note",
                    "entity_id": note["id"],
                    "data": {args["note_status_field"]: args["closed_note_status"]},
# If we have something to do, do it!
if batch_updates:
    sg.batch(batch_updates)
    logger.info(
        'All Notes attached to Task with ID %s will be set to "%s".'
        % (task["id"], args["closed_note_status"])
else:
    logger.info("Task with ID %s: nothing to do, skipping." % task["id"])
def build_updates_for_downstream_tasks(sg, logger, task, batch_updates, args):
Loop through our downstream tasks and append any necessary updates to the
batch_updates list.
:param sg: A Shotgun API handle object.
:param task: A Shotgun Task dictionary.
:param batch_updates: A list sent to a Shotgun API batch command.
:param args: A Dict of user args.
# Return if there are no downstream tasks.
if not task.get(args["downstream_tasks_field"]):
    return
# Re-query all the downstream Tasks to gather their status and downstream
# tasks values.
downstream_tasks = sg.find(
    "Task",
    [["id", "in", [t["id"] for t in task[args["downstream_tasks_field"]]]]],
        args["upstream_tasks_field"],
        args["downstream_tasks_field"],
# Loop through our downstream tasks and append any necessary Task status
# updates to the batch_updates list.
for downstream_task in downstream_tasks:
    # Make sure all upstream Tasks are also set to a valid status.
    upstream_check = True
    if len(downstream_task[args["upstream_tasks_field"]]) > 1:
        for upstream_task in downstream_task[args["upstream_tasks_field"]]:
            upstream_task = sg.find_one(
                "Task",
                [["id", "is", upstream_task["id"]]],
                ["sg_status_list"],
            if (
                upstream_task["sg_status_list"] not in args["task_status"]
                and upstream_task["sg_status_list"]
                not in args["downstream_task_status_recurse"]
                upstream_check = False
                break
    if not upstream_check:
        continue
    if (
        downstream_task.get(args["task_status_field"])
        in args["downstream_task_status_activate"]
                "entity_type": "Task",
                "entity_id": downstream_task["id"],
                "data": {
                    args["task_status_field"]: args["downstream_task_status_active"]
    elif (
        args.get("downstream_task_status_recurse")
        and downstream_task.get(args["task_status_field"])
            sg, logger, downstream_task, batch_updates, args
def all_note_tasks_approved(sg, note, args):
Determine if all Notes on the relevent Task have been approved.
:param note: A Shotgun Note dictionary.
:param args: A dict of plugin args.
:returns: True if all Notes on the relevant Task have been approved, False
          otherwise.
# Re-query all Tasks attached to the Note to gather note_status_field values.
note_tasks = sg.find(
    "Task",
    [["id", "in", [t["id"] for t in note.get("tasks")]]],
    [args["note_status_field"]],
# Loop through all Tasks attached to the Note and return False if any
# note_status_field values are not equal to our task_status.
for note_task in note_tasks:
    if note_task.get(args["note_status_field"]) != args["task_status"]:
        return False
return True
