Could not render and submit the review associated sequence
      I am trying to render and publish single exr from nuke and then load it in photoshop. Knowing it is possible, I am try the publish but perpetually keep getting error
Exception: Review submission failed. Could not render and submit the review associated sequence.
Its a simple read and shotgun write node.
How to solve this ?
We’d need your log files to find out the traceback of the error.
tk-photoshopcc.log (107.9 KB)
we’d need tk-nuke.log
sorry. my bad. confused state.
tk-nuke.log (218.7 KB)
2023-06-26 04:33:03,796 [19024 ERROR sgtk.env.shot_step.tk-nuke.tk-multi-reviewsubmission.tkimp5af16f48cade49d89ef955d99d2538ca.tk_multi_reviewsubmission] Group4.Write1: Invalid LUT selected : Gamma2.2
2023-06-26 04:33:03,859 [19024 ERROR sgtk.env.shot_step.tk-nuke.tk-multi-publish2.tkimp3f5aacfec6c7481bad695123fb4b061f.tk_multi_publish2.dialog] Publish error stack:
  File "P:\software\sgtk\studio39\install\app_store\tk-multi-publish2\v2.6.3\python\tk_multi_publish2\dialog.py", line 1229, in do_publish
    task_generator=self._publish_task_generator()
  File "P:\software\sgtk\studio39\install\app_store\tk-multi-publish2\v2.6.3\python\tk_multi_publish2\api\manager.py", line 345, in publish
    self._process_tasks(task_generator, lambda task: task.publish())
  File "P:\software\sgtk\studio39\install\app_store\tk-multi-publish2\v2.6.3\python\tk_multi_publish2\api\manager.py", line 237, in _process_tasks
    return_value = task_cb(task)
  File "P:\software\sgtk\studio39\install\app_store\tk-multi-publish2\v2.6.3\python\tk_multi_publish2\api\manager.py", line 345, in <lambda>
  File "P:\software\sgtk\studio39\install\app_store\tk-multi-publish2\v2.6.3\python\tk_multi_publish2\api\task.py", line 147, in publish
    self.plugin.run_publish(self.settings, self.item)
  File "P:\software\sgtk\studio39\install\app_store\tk-multi-publish2\v2.6.3\python\tk_multi_publish2\api\plugins\publish_plugin_instance.py", line 204, in run_publish
    self._hook_instance.publish(settings, item)
  File "P:\software\sgtk\studio39\install\app_store\tk-nuke\v0.14.4\hooks\tk-multi-publish2\basic\submit_for_review.py", line 269, in publish
    "Review submission failed. Could not render and "
Invalid LUT selected Gamma2.2
This is your error.
Are you running in an ACES config?
@Ricardo_Musch , this is solved. I have taken a nuke script from artist directly to bypass this error. Thank you
