happy sunday - quick update to my issue which i am yet to fix
I’m essentially trying to publish a mov render that was rendered through the sg write nodes. EXR sequences seem to work fine and the ‘submit for review’ seems to work as expected. But it looks like there is something stopping the mov specificically being submitted through this publisher - and I can’t find where i would change this to allow movs.
Here’s the error log for that process:
2022-08-21 11:31:30,123 [7468 ERROR sgtk.env.project.tk-nuke.tk-multi-reviewsubmission.tkimp73c062c06eba40ff884886e46c7d27b1.tk_multi_reviewsubmission] Group1.source: Z:/projects/projecttest/sequences/test_043_ntc/test_043_ntc_1720_bg001/comp/publish/elements/test_043_ntc_1720_bg001_comp_v001.mov: out of frame range
2022-08-21 11:31:30,149 [7468 DEBUG sgtk.env.project.tk-nuke.tk-multi-publish2.tkimp57707392e13340509d0ca183c69e35ee.tk_multi_publish2.progress.progress_handler] Rendering log action {‘label’: ‘Error Details’, ‘tooltip’: ‘Show the full error tack trace’, ‘text’: ‘
Traceback (most recent call last):\n File “Z:\pipeline\shotgrid\configs\projecttest\install\app_store\tk-multi-publish2\v2.6.2\python\tk_multi_publish2\api\plugins\publish_plugin_instance.py”, line 308, in _handle_plugin_error\n yield\n File “Z:\pipeline\shotgrid\configs\projecttest\install\app_store\tk-multi-publish2\v2.6.2\python\tk_multi_publish2\api\plugins\publish_plugin_instance.py”, line 204, in run_publish\n self._hook_instance.publish(settings, item)\n File “Z:\pipeline\shotgrid\configs\projecttest\install\app_store\tk-nuke\v0.14.4\hooks\tk-multi-publish2\basic\submit_for_review.py”, line 269, in publish\n "Review submission failed. Could not render and "\nException: Review submission failed. Could not render and submit the review associated sequence.\n
’, ‘type’: ‘show_more_info’}
2022-08-21 11:31:30,180 [7468 ERROR sgtk.env.project.tk-nuke.tk-multi-publish2.tkimp57707392e13340509d0ca183c69e35ee.tk_multi_publish2.dialog] Publish error stack:
File “Z:\pipeline\shotgrid\configs\projecttest\install\app_store\tk-multi-publish2\v2.6.2\python\tk_multi_publish2\dialog.py”, line 1229, in do_publish
task_generator=self._publish_task_generator()
File “Z:\pipeline\shotgrid\configs\projecttest\install\app_store\tk-multi-publish2\v2.6.2\python\tk_multi_publish2\api\manager.py”, line 343, in publish
self._process_tasks(task_generator, lambda task: task.publish())
File “Z:\pipeline\shotgrid\configs\projecttest\install\app_store\tk-multi-publish2\v2.6.2\python\tk_multi_publish2\api\manager.py”, line 237, in _process_tasks
return_value = task_cb(task)
File “Z:\pipeline\shotgrid\configs\projecttest\install\app_store\tk-multi-publish2\v2.6.2\python\tk_multi_publish2\api\task.py”, line 147, in publish
self.plugin.run_publish(self.settings, self.item)
Interestingly if I manually drag the mov render into the publisher - rather than seeing the ‘submit for review’ process show up, instead the ‘upload for review’ process shows up instead, and this works perfectly fine and submits the version.
I presume the ‘submit for review’ process expects an image sequence so it can render a movie to upload to Shotgrid? If so, surely there is a way to allow mov’s but switch the task to ‘upload for review’ so it uploads straight away as a version without needing to reprocess it?
Any help would be greatly appreciated - this is one of the last things i am yet to get working
