Copy/paste list of shot ID's to create a playlist
Hi
If you have a list of shot ID’s (link) across several episodes, is there an easy way to copy/paste and:
  • Create a playlist
  • Get e.g. the status for only those shots
Hey @Kenneth.Bonde,
Welcome to the community! You can use a comma separated list in the search panel to find a list of ID’s, just set the criteria to ID. After that you can select all Versions and add them to a playlist with the right click menu.
Depending on what you are searching on you could search for shot code in the link field on Versions and have the Latest checkbox on.
One think to note is that only Versions can be in a playlist, not shots.
filter id3
-David
Thanks! - just what I was looking for
