Confusing behavior: Autodesk login and ShotGrid login
Hi @mmoshev
Autodesk Identity is a form of Single-Sign On. The assumption is that if you are using it for ShotGrid, then you are using it for other things from that same browser (other ShotGrid sites, other Autodesk Cloud products, AKN, support, etc.). It works using cookies, that the login gate of Autodesk Identity sets to keep track of your current session. Once logged-in, all the applications will send you there to authenticate, and you will be automatically redirected back to your application in a logged-in state because of those cookies. Sometimes you will not even realize that this is happening, the back-and-forth happening quick enough so that your browser does not even show a page change.
So having the Sign Out do a global sign out of all active session of Autodesk Identity is a bit like the nuclear option… and may not be want you want. Suddenly finding yourself logged out of all the other apps from an action in just one.
Admittedly, we could add a Sign out of Autodesk Identity which would prompt a warning. For the time being, to log out of you Autodesk Identity user, you usually need to do so from https://profile.autodesk.com or from https://shotgrid.autodesk.com
You can have multiple ShotGrid users associated to the same Autodesk Identity account (usually with different roles, to separate administration from work). Doing a Sign Out of ShotGrid is one way to get back to the user selector screen which is shown when multiple users are associated to the same Identity account (that is what the Switch User menu is for… but it needs more polishing I think).
So the behaviour you are observing is intended.
-Patrick
