I was wondering what are the steps to configure a project to use Python3. I’ve set the SHOTGUN_PYTHON_VERSION environment variable to 3 and was able to launch Shotgun Desktop in Python3 mode. I have also re-setup the project using Advanced Project Setup but the project is still running Python2.7. Is there anything I’m missing?
I could imagine, that one of the two following scenarios may cause the issue:
You’re using an outdated version of tk-core. Check in your configuration: core/core_api.yml
You’re using a pipelineconfiguration, which is pointing to a local-path and includes a file like python_interpreter, interpreter or something like this. If that’s the case, it’s probably best to update this file or to migrate your config into the style of tk-default-config2
