Cinema 4D SetupRender and Playblast App
we are trying to integrate Cinema 4D with Shotgun and we found the fabulous Mykhailo Datsyk files!
Cinema 4D is up and running and the Set Frame range. But we don’t have any luck with:
Of course we are doing something wrong if is not working.
Any help to set up these, step by step?
Playblast has some instructions but no luck with them. What is the way to install a App?
Many Thanks
Hey @Francesc_Macià! Mentioning @Mykhailo_Datsyk so they get a notification and can chime in. :slight_smile:
Hi @johnny.duguid thanks for the tip!
Hi @Mykhailo_Datsyk first of all thanks for your contribution! Your tools for Cinema works really well! Thanks!
But I tried to install the tk-cinema-playblast and tk-cinema-setuprender but because maybe they are not really detailed I made a mistake on the installation. I will start with one.
I copied the tk-cinema playblast into:
install\github\mikedatsik\tk-cinema\v1.0.0\config\env\shot_step.yml
  • ./includes/settings/tk-cinema.yml
engines:
tk-cinema: “@settings.tk-cinema.shot_step”
**tk-cinema-playblast:
** hook_post_playblast: default
** hook_setup_window: default
** location: {name: tk-cinema-playblast, type: manual, version: v0.1.0}
** template_shot_work: cinema_shot_work
** template_shot: cinema_shot_playblast
** template_sequence: cinema_sequence_playblast
** #scale_options: [25, 100]
** #temp_directory: “C:/Temp”
** #camera_name_pattern: “.ShotCam_.”
and I added:
shot_step
settings.tk-cinema.shot_step:
apps:
tk-multi-about:
tk-multi-breakdown: “@settings.tk-multi-breakdown.cinema”
tk-multi-setframerange:
type: git_branch
branch: enable_hooks_for_app
path: GitHub - diegogarciahuerta/tk-multi-setframerange: A Shotgun Pipeline Toolkit App that lets you synchronize the application frame range with the one in Shotgun
version: b24a977
hook_frame_operation: “{engine}/tk-multi-setframerange/frame_operations_tk-cinema.py”
tk-multi-loader2: “@settings.tk-multi-loader2.cinema”
tk-multi-publish2: “@settings.tk-multi-publish2.cinema.shot_step”
tk-multi-screeningroom: “@settings.tk-multi-screeningroom.rv”
tk-multi-shotgunpanel: “@settings.tk-multi-shotgunpanel.cinema”
tk-multi-snapshot: “@settings.tk-multi-snapshot.cinema.shot_step”
tk-multi-workfiles2: “@settings.tk-multi-workfiles2.cinema.shot_step”
menu_favourites:
  • {app_instance: tk-multi-workfiles2, name: File Open…}
  • {app_instance: tk-multi-snapshot, name: Snapshot…}
  • {app_instance: tk-multi-workfiles2, name: File Save…}
  • {app_instance: tk-multi-publish2, name: Publish…}
- {app_instance: tk-cinema-playblast, name: Cinema Playblast…}
template_project: shot_work_area_cinema
under install\github\mikedatsik\tk-cinema\v1.0.0\config\env\includes\settings\tk-cinema.yml
Is it ok?Or I’m missing something important?
Many thanks for your job!
