Can we change fields name for particular projects?
Hello
Is is possible to change the name of some pre existed fields like durations, Bids etc for particular projects only?
I need to customised some of my projects but I also don’t wats to effect other existing projects as well…
Not to my knowledge.
Can you not create a dupliacte field just for the current project and use that instead?
You can change the name of the field with a display label per project I think.
Yeah, looks like that would work, and then ShotGrid renames the field in Filters, etc. with the altered display name and then the name of the field in parentheses.
However what @Ricardo_Musch suggested would also work, and if you needed further customizable options like statuses or whatever that would be easier with a separate field probably.
Oh really? I didn’t know that! That’s neat :slight_smile:
Yes it worked, Thanks a lot guys for suggestions!!
From my experience the renaming of a field header in a list view is a page setting, so just be sure to update it accordingly to all the relevant pages.
