Bootstrap
Hi evryone,
I started to implement a “tk_bootstrap” based on a naive approach based on the Autodesk help with tk-shell implemented.
python-3.9.10
shotgun_api3-3.4.2
tk_core-0.20.32
with SHOTGUN_API_CACERTS pointing to “cacerts.txt” path
Just after this debug messages from logManager():
[DEBUG sgtk.core.util.storage_roots] Querying SG local storages…
context = _build_ssl_context(
  File "/opt/prod/packages/external/tk_core/0.20.32/python/tank_vendor/shotgun_api3/lib/httplib2/python3/__init__.py", line 183, in _build_ssl_context
    context.load_verify_locations(ca_certs)
FileNotFoundError: [Errno 2] No such file or directory
If anybody have any idea about debugging this part.
Best regards,
Mathieu
Hi @mnegrel !
Did you install tk-core via pip in a virtual env? If so there is a long standing bug where this breaks the bootstrap API. Pip install sgtk breaks ToolkitManager
Best solution we found so far is installing tk-core in editable mode.
Hope that helps!
Cheers
Fabian
Hi Fabian,
first of all thank you so much for reply.
I do not install with pip because I already had a bug like this few years ago.
From my part it’s looks like I have an authentification issue, append right after updating tk-core, and shotgun api.
I would more time next week end to dive into the code understand clearly what appended.
Best regards
Doesn’t this just mean that it cant access the cacerts file?
I do not know, I tryed différents ways using SHOTGUN_API_CACERTS and SSL_CERT_FILE with the path to cacert.pem and or cacert.txt.
I have couple of time this week end for that.
I will put the result if I find some thing
