Hey everyone,
I am currently working on running the shotgrid publisher on the farm.
It involves starting the software, in this case maya, and bootstrapping the tk-maya engine with the right context.
Currently I have the issue that shotgrid complains that it does not find the engine instance in the env/site.yml file when I try to start it.
I then went ahead and added a tk-maya entry in the site.yml file under engines.
includes:
- ./includes/frameworks.yml
- ./includes/settings/tk-desktop.yml
- ./includes/settings/tk-desktop2.yml
- ./includes/settings/tk-maya.yml
# configuration for all engines to load in a project context
engines:
tk-desktop: '@settings.tk-desktop.site'
tk-desktop2: '@settings.tk-desktop2.site'
tk-maya: '@settings.tk-maya.site'
I also added the “site” section in the env/includes/settings/tk-maya.yml file.
settings.tk-maya.site:
apps:
tk-multi-publish2: "@settings.tk-multi-publish2.maya.shot_step"
In the apps section I added the tk-multi-publish2 entry and set it up to use the shot_step settings as I am running a shot publish on the farm.
Now this feels very dirty to me because I would like to bootstrap the tk-maya engine in my python script with the already defined settings.tk-maya.shot_step settings.
I don’t want to use the default site config that I have to then adjust in the yml files to work with my specific shot case.
But I didn’t find a way how to do that. When bootstrapping it seems to always use the site config as default?
Can I somehow control that? This is how I currently do the bootstrap:
# Set up logging.
sgtk.LogManager().initialize_base_file_handler("tk-batch-rendering")
user = sgtk.authentication.ShotgunAuthenticator().create_script_user(
os.environ["SHOTGUN_SCRIPT_NAME"],
os.environ["SHOTGUN_SCRIPT_KEY"],
os.environ["SHOTGUN_HOST"]
# Set the right pipeline configuration.
tk_manager = sgtk.bootstrap.ToolkitManager(user)
tk_manager.plugin_id = "basic.batch"
tk_manager.pipeline_configuration = configuration_id
# Sync the path cache before the engine starts. The engine validates the templates
# when it starts so path cache has to be already synced.
tk_manager.pre_engine_start_callback = lambda ctx: ctx.sgtk.synchronize_filesystem_structure()
# Start the engine, we're done!
tk_manager.bootstrap_engine(engine_instance_name, context)
Would love to get some tips!
