I’m trying to leverage TK_BOOTSTRAP_CONFIG_OVERRIDE and the Bootstrap mechanism to launch tk-maya. It works up until the point where I try to open a file through the workfiles app, and the engine needs to be refreshed. At that point, I get the following error:
TankInitError: You are loading the Toolkit platform from the pipeline configuration located in '/Users/brhoades/Library/Caches/Shotgun/<config-name-redacted>/p253/cfg', with SG id None.
The refresh_engine is trying to create a new sgtk object via sgtk.sgtk_from_path. It is able to recognize that it’s running within a project, however it fails to match the path to a Pipeline Configuration.
It seems to be looking for a Pipeline Configuration ID, but of course, since I’m using the override, there’s no associated Pipeline Config in ShotGrid.
Did I mistakenly assume that the Bootstrap override works? Is there some other setting that I need to specify to indicate that it isn’t supposed to try to lookup Pipeline Configurations from ShotGrid?
