Bluejeans screen sharing black screen
When running Shotgun Create and then sharing my screen through the video chat program bluejeans, the shared screen goes totally black. I believe this is a bug. I’m only testing Shotgun Create lately and I don’t have much reference to this happening.
Mark Thielen
Hi @mdthielen.
What were you doing in Shotgun Create while sharing the screen? Did everything looked fine on your side of the session?
Kerby
I had a image file open in the review. Everything looked fine before I clicked on the bluejeans share screen button. Then the shared screen went black.
By saying “Then the shared screen went black.”, do you mean that…
  • Everything in your monitor went black?
  • The Shotgun Create window from your monitor went black?
  • The Shotgun Create player from your monitor went black?
  • The peer at the other end of the video chat received a black video stream?
  • The peer at the other end of the video chat received everything correctly except the Shotgun Create window went black?
  • The peer at the other end of the video chat received everything correctly except the Shotgun Create player went?
I have 2 monitors. The monitor I clicked to share was completely black and the other monitor was normal. The Sg create window was on top of other windows on the shared monitor. I couldn’t see anything but black.
The peer side saw that there was a thin rectangular box at the very top of the screen, about 4” wide and maybe a 1/4” high. Very small. The rest of the screen was black.
Mark
Is this happening on Windows, macOS or Linux?
What is the version of the operating system? Have you ever seen something similar using RV?
What is your GPU model?
This is on windows 7. I’ve never seen this behavior on RV with bluejeans. I tested again today and can only see the bluejeans controls for sharing and black within.
Also I noticed since I did the screen share with Sg create, I cannot screen share anything else. I get black screens. I even shut down Sg create , Sg desktop, and rv with no fix. I will need to try a reboot.
Hi Mark,
First, we are really sorry for the trouble caused by the problem. We now have a ticket open in our backlog about this issue so we can reserve some time to troubleshoot this issue.
Kerby
