Best practices: How to display deadlines & other calendar events?
Hi all…I’m just wondering what is the best way to enter one-day calendar events like deadlines and ‘client’ reviews and view them.
I am currently adding special dates as one-day Phases and then turning on the Phases & Milestones option on in the Gantt view. There they show up as a vertical black stripe in the Gantt view, with the related Phase info when I hover over the stripe.
So, is there a better way I should be doing this?
Can I change the color of the black strip to something more obvious?
If I put these Phase events in a Project Template, will they propagate to the projects created from the template? (I think yes, right?)
Chad
Hi Chad,
I think what you are doing now is the best way to show one-day calendar event. You could submit a new feature to polish it. Here is article how to submit a new feature.
The color can be changed. If you set the phase to use project color, the strip will follow project color.
The phase event can’t be save in the project template. Because the event isn’t part of setup. It is data.
Hope it is helpful.
Best Regards
Loney
Hi Chad,
We’re also working on resolving a current bug where the Phase overlays in the Gantt are always appearing as black, rather than respecting the colors you chose in the Project Timeline app.
Once that is resolved you should get the different colors in the gantt.
Thanks for the info, Loney. At least I am using the best workaround available. I’ll look into submitting a feature request. But at least this works for now. (aside from the bug mentioned below)
Cheers
Chad
Thanks for the heads up on that bug, Brandon. Not a show-stopper at least.
Cheers
Chad
Hey Chad, I’m just doing some spring cleaning and wanted to flag to you that we fixed the issue with Phases and Milestone colors in the gantt as of Shotgun 8.8.0.3165 (just in case you didn’t see that in the other thread that Brandon linked up). Sorry for the delay in letting you know about this!
Hey Jessica,
Thanks for the update on this. I hadn’t check out the issue in a while, but it’s good to know it is fixed!
Cheers
Chad
My pleasure, Chad!
