I want to use ’Annotation.StoreOnSrc’ setting (Annotation->Configure->Draw On Source When Possible) to store the annotation info to the first source node.
However, when I add an annotation at stack mode, the annotation info is still stored in the stack node even though I set the StoreOnSrc option.
When I see ‘annotation_mode.mu`, I think the line #229 should check “if (sourcePaintCount < 1)”
(Or maybe you can simply with checking _currentNodeInfo is nil, instead using sourcePaintCount.)
Otherwise the first item in infos (which is the RVPaint node for the current stack, in my case) is set to _currentNodeInfo and _currentNode.
I am testing with RV2022.3.1, but I also checked with RV2023.0.1: the logic is the same.
What do you think?
