Ability to limit statuses in cut tray by project
We currently have multiple “types” of projects in ShotGrid, so we use different Version statues for each project. Normally, within the context of a project in ShotGrid, the interface only shows the available Version statuses.
In RV, in the cut tray, even though I would expect the cut to be project-aware, the “Filter by Status” panel shows all available Version statuses, even if not active for this project.
Is there a way to limit this? Or is this even a bug?
I would say its likely a misimplementation where the code is just pulling all statussed without a filter mechanism for the current project.
It should certainly be aware of the project and show the same thing across all places.
