A new version of tk-framework-shotgunutils has been released!
Welcome to the release notes for this Framework. Below you will find an overview of all the changes we did for each release. We try to be as detailed as possible and include all bugs we have fixed, features we have added and things that may have changed. If you have questions about a particular release, don't hesitate to contact our support team!
v5.8.1
2021-Sep-16
Set the cwd of the external_runner
v5.8.2
2021-Oct-01
Add a method to check if an entity type is in the schema.
v5.8.3
2021-Nov-18
Fixes an issue with ShotgunModel when displaying refreshed data.
v5.8.4
2021-Nov-30
Replacing shotgunsoftware urls with Autodesk Knowledge Network and ShotGrid Developer Documentation pages.
v5.8.5
2022-Mar-28
ShotGrid branding updates.
v5.8.6
2023-May-18
Fix user settings to handle QByteArray values. Formalize the deprecation of Python 2.6 support in toolkit.
v5.8.7
2023-Oct-27
  • Supports Python 3.10 syntax
v5.8.8
2024-Feb-6
  • Fix order when adding new items before caching
  • Fix ShotgunDataRetriever Errors for Items without a Thumbnail
v5.10.0
2024-Jun-20
Pyside and Qt4 code cleanup
v5.10.1
2024-Sep-9
Drop Python 2 compatibility - part 1 & New Qt UI resource process
v5.10.2
2025-Feb-6
  • Removed Python 2 code.
v5.11.1
What's Changed
  • UserSettings - Error details: 'str' object has no attribute 'decode' (SG-40414 - PR #170)
v5.11.2
Add VFX CY2026 support, fix segfault and remove PySide1 references.
What's Changed
  • Fix Python syntax warnings related to regexp exclude character (SG-40620 - PR #172)
  • Remove outdated references to PySide1 (SG-39031 - PR #174)
  • Fix random segfault by controlling Qt object destruction order (SG-42069 - PR #178)
  • Add support for VFX CY2026 - Python 3.13 - Qt 6.8 (SG-40980 - PR #175)
Full Changelog: https://github.com/shotgunsoftware/tk-framework-shotgunutils/compare/v5.11.1...v5.11.2
v5.11.3
Drop Python 3.7 support and fix ShotgunHierarchyModel errors
What's Changed
  • Drop Python 3.7 support (SG-43665 - #179)
  • Fix an AttributeError in ShotgunHierarchyModel when the first path is not loaded (SG-45127 - #180)
New Contributors
  • @stevelittlefish made their first contribution in #179
Full Changelog: https://github.com/shotgunsoftware/tk-framework-shotgunutils/compare/v5.11.2...v5.11.3
