A new version of tk-framework-adobe has been released!
Welcome to the release notes for this Engine. Below you will find an overview of all the changes we did for each release. We try to be as detailed as possible and include all bugs we have fixed, features we have added and things that may have changed. If you have questions about a particular release, don't hesitate to contact our support team!
v1.1.4
2021-Nov-30
Replacing shotgunsoftware urls with Autodesk Knowledge Network and ShotGrid Developer Documentation pages.
v1.1.5
2022-Mar-28
ShotGrid branding updates.
v1.1.6
2022-Jun-16
Added a method to export the document as an image
v1.1.7
2023-Jan-24
Change the color of the ShotGrid hyperlinks to be contrasted enough with the background.
v1.1.8
2023-Apr-27
Bump certifi from 2020.6.20 to 2022.12.7
v1.1.9
2023-Sep-6
  • Bump certifi from 2022.12.7 to 2023.7.22
  • Bump requests from 2.25.0 to 2.31.0
v1.1.10
2023-Feb-6
  • Internal documentation changes
  • Upgrade urllib3 to 2.1.0
v1.2.2
2024-May-9
Update idna to 3.7
v1.2.4
2024-Sep-9
  • import six replaced by sgutils for ensure_* funcs
  • Add Python 3.11 modules
v1.2.5
2024-Oct-24
  • New env variable SHOTGUN_ADOBE_SERVER_PING_TIMEOUT allows us to initialize the Node server with a higher pingTimeout, this defines how often the server sends a "ping" to the client to check that the connection is still active
v1.2.6
2024-Dec-2
Use TK Core logic to check if PySide is available in the environment instead of depending on direct PySide imports. This creates a more maintainable code across PySide versions.
v1.2.7
2024-Dec-16
The Panel JS closes correctly after the Manager JS is closed.
v1.2.8
2025-Feb-6
  • Removed Python 2 code.
  • Requirements for pkgs.zip updated.
v1.2.9
2025-Feb-19
  • Certifi upgrade to 2024.12.14.
v1.2.10
2025-Mar-6
  • Hook for socketIO prepare_http_session.
  • Env var to enable proxy.
v1.2.11
What's Changed
  • Removed try/except sgutil blocks and ensure_ methods by @eduardoChaucaGallegos in https://github.com/shotgunsoftware/tk-framework-adobe/pull/90
  • New CEP plugin - fixing ZXP sign issue by @eduardoChaucaGallegos in https://github.com/shotgunsoftware/tk-framework-adobe/pull/92
Full Changelog: https://github.com/shotgunsoftware/tk-framework-adobe/compare/v1.2.10...v1.2.11
v1.2.12
Add VFX CY2026 support, and update dependencies.
What's Changed
  • Update "requests" package to 2.32.5 (SG-39341 - PR #94)
  • Add support for VFX CY2026 - Python 3.13 - Qt 6.8 (SG-40981 - PR #101)
  • Upgrade certifi from 2024.12.14 to 2026.1.4 (SG-39923 - PR #103)
Full Changelog: https://github.com/shotgunsoftware/tk-framework-adobe/compare/v1.2.11...v1.2.12
