v0.23.6
PySide/Qt4 cleanup, VFX CY2026 support and prevent autoupdate.
What's Changed
- Removed outdated references of PySide/Qt4 (SG-39031 - PR #1079)
- Fix deprecation warnings for QTextCodec.setCodecForCStrings() (SG-41647 - PR #1083)
- Add support for VFX CY2026 - Python 3.13 - Qt 6.8 (SG-40980 - PR #1080)
- Prevent tk component autoupdate (SG-40996 - PR #1077)
Full Changelog: https://github.com/shotgunsoftware/tk-core/compare/v0.23.5...v0.23.6
v0.23.8
Fixes and improvements to context and packaging.
What's Changed
Fixed FileNotFoundError was being raised incorrectly, improving error handling behavior (SG‑40807 – PR #1088).
Made website‑originated context available in the FPTR menu for more seamless workflows (SG‑41800 – PR #1089).
Introduced a new approach for handling Python third‑party dependencies, improving maintainability and consistency (SG‑37222 – PR #996).
Fixed a missing __init__.py file in the ruamel module, ensuring proper package initialization (SG‑41902 – PR #1087).
Full Changelog: https://github.com/shotgunsoftware/tk-core/compare/v0.23.7...v0.23.8
v0.23.9
We’ve focused on resolving edge cases and refining core behaviors to ensure smoother operation across the platform.
What's Changed
- Removed the no-preview.jpg placeholder to provide a cleaner and more predictable upload experience. (SG-41375 - PR #1093)
- Adjusted the module initialization order to prevent unexpected behavior during application startup. (SG-43219 - PR #1092)
- Fixed a race condition that could occasionally disrupt the login process. (SG-33297 - PR #1095)
- Improved how paths are interpreted to reduce mismatches and ensure more reliable behavior. (SG-37743 - #1097)
- Resolved an issue where the running API version might not be correctly identified in certain pip installation scenarios. (SG-42277 - PR #1096)
New Contributors
- @th-jyu made their first contribution in https://github.com/shotgunsoftware/tk-core/pull/1092
- @yungsiow made their first contribution in https://github.com/shotgunsoftware/tk-core/pull/1097
- @stevelittlefish made their first contribution in https://github.com/shotgunsoftware/tk-core/pull/1096
Full Changelog: https://github.com/shotgunsoftware/tk-core/compare/v0.23.8...v0.23.9
v0.23.10
Removed Python 3.7 support, fixed SHOTGUN_API_CACERTS defect
What's Changed
- SG-43667 Remove Python 3.7 support by @stevelittlefish in https://github.com/shotgunsoftware/tk-core/pull/1107
- Preserve SHOTGUN_API_CACERTS precedence in shotgun_api3 cert patch by @stevelittlefish in https://github.com/shotgunsoftware/tk-core/pull/1122
- SG-43675 Upgrade PyJWT to 2.12.0 to resolve CVE-2026-32597 by @stevelittlefish in https://github.com/shotgunsoftware/tk-core/pull/1106
Full Changelog: https://github.com/shotgunsoftware/tk-core/compare/v0.23.9...v0.23.10
v0.24.0
Final removal of python 3.7 support from python api, long paths fix for Windows
What's Changed
- SG-44086 Unzip long paths by @carlos-villavicencio-adsk in https://github.com/shotgunsoftware/tk-core/pull/1118
- Bump shotgun_api3 to 3.10.3 across all Python version requirements by @stevelittlefish in https://github.com/shotgunsoftware/tk-core/pull/1123
Full Changelog: https://github.com/shotgunsoftware/tk-core/compare/v0.23.10...v0.24.0
v0.24.1
Fixed several Toolkit support issues.
What's Changed
- Fixed temporary git clone directories not being deleted when they contained read-only files. (SG-43353)
- SFixed TemplatePath.parent silently stripping optional bracket syntax from templates, which caused files to disappear from Workfiles listings. (SG-38756)
- Fixed tank core upgrade failing with ModuleNotFoundError: yaml when upgrading from tk-core v0.23.6 or older to v0.23.7 or newer. (SG-44721)
New Contributors
- @BoubQC made their first contribution in https://github.com/shotgunsoftware/tk-core/pull/845
- Thanks to community contributor @ClementHector for the fix to TemplatePath.parent with optional keys!
Full Changelog: https://github.com/shotgunsoftware/tk-core/compare/v0.24.0...v0.24.1
v0.24.2
Mask secrets in Git descriptor URLs and remove obsolete dependencies
What's Changed
- Mask secrets in Git descriptor URLs (SG-44103 - #1131)
- Remove obsolete Python 2-era vendored unit-test dependencies (SG-45235 - #1134)
Full Changelog: https://github.com/shotgunsoftware/tk-core/compare/v0.24.1...v0.24.2
