Windows Global Bundle Cache Location
Hi all,
Based on the documentation, the global bundle cache on Windows should be found at:
%APPDATA%\Shotgun\Caches\bundle_cache
However, the location on disk for our studio seems to be
%APPDATA%\Shotgun\bundle_cache
Is this correct? Also, in the documentation on this page:
Descriptor Docs
It mentions “Unless specified otherwise, this is the location where descriptors will be cached locally”. My question here is, where do you specify otherwise? Is this specified on a file on disk or perhaps in the Shotgrid website?
Hey Bryce,
from my experience the second path looks accurate.
You can set an environment variable called SHOTGUN_BUNDLE_CACHE_PATH which will reroute the Shotgrid bundle cache folders to the location you specify.
There are other Environment variables you can set as well, listed here:
https://developer.shotgridsoftware.com/tk-core/environment_variables.html
