What are some useful python snippets for working in RV?
Most of the Python commands are actually bindings on top of Mu commands. Mu is a native RV scripting language.
You can find most of the API documentation by launching RV then going Help → Mu Command API Browser.
The most useful modules are rv.commands and rv.extra_commands. These are the bulk of operations that you can perform in RV.
Quick initial example
initial import
from rv import commands
from rv import extra_commands
Get all of the sources that are available at a specific frame
sources = commands.sourcesAtFrame(frame)
Get metadata info
print commands.sourceMediaInfo(sources[0])
print commands.sourceAttributes(“RVFileSource”)
Get file names
fileNames = commands.getStringProperty(“%s.media.movie” % sources[0], 0, 1000)
fileName = fileNames[0]
Get annotated frames
frames = extra_commands.findAnnotatedFrames()
Set Stack view to be default
commands.setViewNode(‘defaultStack’)
Setting up an Example Look Pipeline
Initial Import
from rv import commands, extra_commands
Get the last source at current frame
source = commands.sourcesAtFrame(commands.frame()[0])
Find the source group
sourceGroup = commands.nodeGroup(source)
Find the look pipe group that is on the source group
lookPipe = extra_commands.nodesInGroupOfType(sourceGroup, “RVLookPipelineGroup”)[0]
Set the order of the look pipe operations
commands.setStringProperty(“%s.pipeline.nodes” % lookPipe, [“LinearToAlexaLogC”, “RVLookLut”, “rec709ToLinear”], True)
Find nodes of type RVLookLUT
looklut = commands.nodesInGroupOfType(“%s.pipeline.nodes”, “RVLookLUT”)
commands.nodeType(lookLUT)
Set the LUT file path on the node you found
commands.setStringProperty(“%s.lut.file” % “/path/to/cube”)
More tips for using Mu via Python
Sometimes some Mu commands aren’t bound in Python. In this case you have 2 ways of calling Mu from Python:
  1. If symbol exists in Mu but isn’t bound to python:
from pymu import MuSymbol
mute = MuSymbol(“rvui.isMuted”)
mute()
  1. If the symbol is either private or isn’t bound anywhere, you can directly evaluate Mu from Python:
import rv
rv.runtime.eval(“rvui.isMuted(); 1;”, [“rvui”])
Awesome post @alexaz ! I added your examples to the RV Cookbook - How to get things done with RV in Python
This crashes RV immediately now
import rv
rv.runtime.eval("rvui.isMuted(); 1;", ["rvui"])
And this
mute = MuSymbol("rvui.isMuted")
mute()
returns the error
Exception: Mu symbol is not a function -- cannot call
